CambridgeCabby Posted July 13, 2021 Share Posted July 13, 2021 5 minutes ago, Hylander said: Do you really need a map - I would have thought you could find your way around the Broads blind fold. Well he knows it backwards , especially Wroxham bridge 1 2 Quote Link to comment Share on other sites More sharing options...
Captain Posted July 13, 2021 Share Posted July 13, 2021 Just checked the Woods website the £4 map is provided complimentary unless you want more than one copy Neil 2 Quote Link to comment Share on other sites More sharing options...
750XL Posted July 13, 2021 Author Share Posted July 13, 2021 May I ask peoples opinions on the usage of warm air heating overnight? I won't name the boatyards, but during our first out of season trip on another boat during the handover we were told it's fine to leave the diesel warm air heating on overnight no problem at all. Another year at a different boatyard we were told the electric warm air heating should only be used for brief periods, and not left on overnight. What are the pros and cons to leaving the warm air heating on overnight? Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted July 13, 2021 Share Posted July 13, 2021 Major cons can be melting you or your neighbours fenders if stern moored or scorching their gelcoat, it is b****y noisy as far as your near neighbour is concerned . The drain on the domestic batteries also 1 Quote Link to comment Share on other sites More sharing options...
DAVIDH Posted July 13, 2021 Share Posted July 13, 2021 Quite apart from what running the heating's fan overnight would do to the batteries, I wouldn't feel safe sleeping in a cabin being fed warm air (and who knows what other fumes if not running correctly) from a heating system. 3 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted July 13, 2021 Share Posted July 13, 2021 17 minutes ago, 750XL said: May I ask peoples opinions on the usage of warm air heating overnight? I won't name the boatyards, but during our first out of season trip on another boat during the handover we were told it's fine to leave the diesel warm air heating on overnight no problem at all. Another year at a different boatyard we were told the electric warm air heating should only be used for brief periods, and not left on overnight. What are the pros and cons to leaving the warm air heating on overnight? You mention two different systems (?). Quote Link to comment Share on other sites More sharing options...
750XL Posted July 13, 2021 Author Share Posted July 13, 2021 1 minute ago, OldBerkshireBoy said: You mention two different systems (?). These were 2 different experiences from 2 different yards I believe one was a Webasto(sp) diesel heater? Which was very warm The other was an electric heating system, which wasn't very warm. 1 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted July 13, 2021 Share Posted July 13, 2021 If the boat you’re on has shore power , bring an oil filled radiator and plug it in (don’t use inverter when moored up for heating) 2 Quote Link to comment Share on other sites More sharing options...
oldgregg Posted July 13, 2021 Share Posted July 13, 2021 I wouldn't leave it on overnight. As others have said, it's not beyond the realms of possibility for exhaust gases to end up in the ducting if something goes wrong. There have been many high-profile incidents over the years involving CO poisoning on boats, none of them are pretty. Use electric heating on shore power overnight (ie an oil radiator with tilt sensor) and don't overload the supply. It's a 16 amp supply, not 100 like you have at home, and is usually shared with an immersion heater and battery charger. 2 Quote Link to comment Share on other sites More sharing options...
Cal Posted July 13, 2021 Share Posted July 13, 2021 We used to use our boat all year round and in the depths of winter did leave our diesel heating on overnight although turned down. More often than not though we just had the duvet and an extra fleece blanket which kept us toasty warm. We plan to use our van all year round and will leave the gas heating on low overnight when it is cold enough to warrant it. Quote Link to comment Share on other sites More sharing options...
oldgregg Posted July 13, 2021 Share Posted July 13, 2021 20 minutes ago, Cal said: We plan to use our van all year round and will leave the gas heating on low overnight when it is cold enough to warrant it. The difference with a camper is that the exhaust gases exit through the floor where there's a big air gap underneath and even if there's a leak they're likely to do that. In a boat, it's all going to end up in the bilges.. Quote Link to comment Share on other sites More sharing options...
annv Posted July 13, 2021 Share Posted July 13, 2021 Hi We have two electric 4 position under blankets that we use, there shouldn't be a problem in leaving the heating on over night, you after all may have it on all day, if your concerned take a carbon monoxide censer with you they are cheap as chips, or though the boat should have one fitted, warm air heating does dry the air and may give you a dry mouth. John Quote Link to comment Share on other sites More sharing options...
vanessan Posted July 13, 2021 Share Posted July 13, 2021 I doubt if you would need heating all night in October. We usually find that the heat from the cooker takes care of any chill in the evenings and only put the heating on in the morning to take the chill off if it’s needed. Hot water bottles can be useful too. Quote Link to comment Share on other sites More sharing options...
tim Posted July 13, 2021 Share Posted July 13, 2021 8 hours ago, BroadAmbition said: Laminated copy? New item on the shopping list for me then - thanks Griff After posting that I tried to get a link but couldn’t get one so I emailed them and got this reply hope it helps Hi Tim If you follow the link to Guidepost from our website page they will be able to sell you a laminated copy. Thanks Nick Heron Maps 1 Quote Link to comment Share on other sites More sharing options...
YnysMon Posted July 13, 2021 Share Posted July 13, 2021 We have also found October weeks quite mild at nights. Early spring weeks much colder. For cold nights water bottles usually come in handy. For extra chilly nights we have a little dimplex radiator, though that depends on being plugged into shore power. We first took one with us when hiring Fair Regent. Quote Link to comment Share on other sites More sharing options...
RS2021 Posted July 13, 2021 Share Posted July 13, 2021 I remember hiring a boat in the 1990s which proudly proclaimed 'the central heating can be controlled from in bed'. You could stay snug under the duvet and switch the heating on before you get up! 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted July 13, 2021 Share Posted July 13, 2021 During winter onboard 'B.A' we leave the heating on overnight albeit turned down on the thermostat, have done so on many occasions with no issues at all. We will do so again this coming winter no doubt. Running out of amps on the batteries is not really an issue for us. I always check the exhaust outlet with regards to other boats / fenders previously though Griff Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted July 13, 2021 Share Posted July 13, 2021 If you follow the link to Guidepost from our website page they will be able to sell you a laminated copy. Did that but nowhere on the Guidepost site is there an option to order the laminated version, I will have to ring them tomorrow. Tks for your help all the same Griff Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted July 13, 2021 Share Posted July 13, 2021 Griff, I`ll guess it is out of stock because you do get the option on other maps. 1 Quote Link to comment Share on other sites More sharing options...
750XL Posted July 13, 2021 Author Share Posted July 13, 2021 Thanks for all the informative replies as ever, it's interesting to see peoples varying opinions. Quote Link to comment Share on other sites More sharing options...
YnysMon Posted July 13, 2021 Share Posted July 13, 2021 2 hours ago, BroadAmbition said: I always check the exhaust outlet with regards to other boats / fenders previously though I vividly recall one night, about four years ago, moored up at Rockland St Mary Staithe in one of the Fair Regents (on electric) being bothered all evening and (even worse) all night by the sound of the heating outflow from the boat next to us. The boat was a falrly recent addition to the Ferry Marina fleet with a young couple aboard. They left the heating on all evening whilst they were in the pub, and then all night. So, if you are tempted to have your heating on overnight, just bear in mind, that heating can sound a lot louder to the boat next to you than it does in your boat! We had our little dimplex with us and we were cosy (and silent!). 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted July 13, 2021 Share Posted July 13, 2021 Yes the heater noise on some craft can be somewhat obtrusive. Our Planar heater seems quieter than most plus I have fitted a silencer to the exhaust system, as much for our own benefit as well as others, on tickover (Nightime running) its proper quiet Griff 2 Quote Link to comment Share on other sites More sharing options...
750XL Posted July 13, 2021 Author Share Posted July 13, 2021 The last few boats we've had, I specifically listened to how loud it was from the outside. Both times, almost silent. But have noticed in the past some larger boats have noisy whooshing, whistling and howling heating systems 1 Quote Link to comment Share on other sites More sharing options...
Cheesey69 Posted July 14, 2021 Share Posted July 14, 2021 All hired boats have carbon monoxide alarms, so rest easy. Unless something is severely wrong its safe. But tip a nod to the noise and hot gas exhaust. The more modern ones have a thermostat so you wont boil alive unlike mine which is on full power all of the time. I consider the greater danger of other craft pumping carbon monoxide into my boat more to worry about as happened to me at Beccles when the boat next door ran its heating. The alarm went off. Quote Link to comment Share on other sites More sharing options...
SwanR Posted July 14, 2021 Share Posted July 14, 2021 Winter pjs, hot water bottle and a good sleeping bag. I would never consider leaving the heating on overnight. 2 Quote Link to comment Share on other sites More sharing options...
