Ray Posted August 3, 2021 Share Posted August 3, 2021 Has anyone had it fitted? I wonder if the benefit is worth the expense. I know it can look nice but I'm guessing a professional service including floor hatches is not going to be cheap! Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 3, 2021 Share Posted August 3, 2021 I have it in the scorpio, great carpet always cleans up. I also have a plain light blue fitted on Whitey in the rear cabins. Hoovers up nice and any marks wipe off. We had oil marks on it after a service, this came off without a problem. All areas are fixed with press studs in each corner and it stays firm and doesn't distort. 1 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted August 3, 2021 Share Posted August 3, 2021 Yes, we had it supplied / fitted in all cabins onboard 'B.A' - Very impressed with it Griff 2 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted August 3, 2021 Author Share Posted August 3, 2021 Did you both use local companies that you'd recommend and if it's not rude to ask, was it expensive? I know BA must have taken twice as much as I'd need (approx) Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted August 3, 2021 Share Posted August 3, 2021 We used:-Β TrimnetΒ Ltd TurksΒ Shipyard HistoricΒ Dockyard Chatham UnitedΒ Kingdom The cost for supplying and fitting was Β£363:00 that was for the Fwd bow cabin, Fwd Port and Stbd cabins, the double cabin with a tiny piece for the quarter berth It was fitted April 2017 and still looks like new.Β You can jet wash the stuff! - not that we have ever needed to.Β It comes in a range of choices / colours. Recommended - if you get the genuine stuff Griff Β 3 3 Quote Link to comment Share on other sites More sharing options...
Ray Posted August 3, 2021 Author Share Posted August 3, 2021 Beautiful and a bargain by the sound of it! Thanks Griff π 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted August 3, 2021 Share Posted August 3, 2021 Brings back some memories. I was largely involved in releasing this to the UK market. It is good stuff and it's still pretty cool to see boats with it installed.Β Go for templating yourself. If you get stuck and on the northern rivers I maybe able help with templating. 1 2 Quote Link to comment Share on other sites More sharing options...
PCL023 Posted August 3, 2021 Share Posted August 3, 2021 We use EVA boat flooring. It has a very strong self adhesive backing which is stuck to boards, it to can be lifted taken home and pressure washed if ever needed.Β Itβs mainly for outside deck use such as fly bridges etc. Inside the boat itβs greatΒ and soft under foot. Any impressions from items like chairs disappear.Β Water proof and wipe clean etc. Plenty of the stuff on the supplierβs of choice sites, such as the bay, many colour options and roll sizes. We did the lot with 5 rolls at about Β£38.00 per roll. (120x90)Β Very easy to fit, and cheap enough if it fails after a few years,Β though itβs holding up just fine after the first year of abuse.Β Just did the last part in the cockpit the other month. ( alloy edging trimsΒ also now installed). it could be worth a look?Β Cheers Paul 1 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted August 3, 2021 Author Share Posted August 3, 2021 You've done a great job, she looks fantastic! Definitely an option, the aluminium edging gives a really professional looking finish π Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 4, 2021 Share Posted August 4, 2021 Found a couple of photos of the blue in situ. The binding is well worth having. 2 Quote Link to comment Share on other sites More sharing options...
Ray Posted August 4, 2021 Author Share Posted August 4, 2021 I see what you mean, the binding gives it the proper finished look. Very smart π 1 Quote Link to comment Share on other sites More sharing options...
Malanka Posted August 4, 2021 Share Posted August 4, 2021 EwwΒ want it want it want it .... 1 Quote Link to comment Share on other sites More sharing options...
oldgregg Posted August 4, 2021 Share Posted August 4, 2021 Edgebound looks great, and makes it easy to remove for cleaning without things getting scruffy.Β I believe Ludham Carpets can do it, and are also decent value. 2 Quote Link to comment Share on other sites More sharing options...
Bluebell Posted August 4, 2021 Share Posted August 4, 2021 We had Trimnet supply ours back in 2017. Alan (JawsOrca) measured up for us and when it arrived by carrier all we had to do was roll it out - it fitted perfectly. Iβm afraid I Β canβt remember the cost (best to forget these things!) Would highly recommend it, weβre considering it for our current boat as its carpet is now 25 years old π 1 1 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted August 4, 2021 Share Posted August 4, 2021 2 hours ago, oldgregg said: Edgebound looks great, and makes it easy to remove for cleaning without things getting scruffy.Β I believe Ludham Carpets can do it, and are also decent value. Cromer Carpets also have a first rate binding service 1 Quote Link to comment Share on other sites More sharing options...
