Clipper Depth Gauge
My depth gauge hasn't worked for months with no power to it, I have finally found the fault and rectified it. However now it's working the readings seem off, my question is if the unit has been without power for a while does it need resetting up , and if so how? Thx
I never got ours to work when inside the hull.. It used to work on our other boat but anything which attached to it would throw it out.. (I don't believe it needs setting up other setting the hull offset - I believe other causes for misreadings is electrical interference from electric circuits, they really like to be some distance from such.. Good luck..
