floydraser Posted August 30, 2021 Share Posted August 30, 2021 Just a heads up for anyone who, like me, uses brushes once then chucks them away. https://www.lidl.co.uk/p/diy/paintbrush-set/p45121 I'll be slicing the two widest ones down the middle to make two smaller ones for use with resin. 1 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted August 30, 2021 Share Posted August 30, 2021 30 minutes ago, floydraser said: Just a heads up for anyone who, like me, uses brushes once then chucks them away. https://www.lidl.co.uk/p/diy/paintbrush-set/p45121 I'll be slicing the two widest ones down the middle to make two smaller ones for use with resin. Toolstation does cheap throw-away brushes much cheaper than this. If you're just using them for resin, these are perfect. Not so goon on gel as they tend to shed a bit, but if you condition them before use, they are better. https://www.toolstation.com/paintbrush-set/p48839 These have gone up my 50% in the last 14 months. They used to be £0.99p 1 Quote Link to comment Share on other sites More sharing options...
floydraser Posted August 30, 2021 Author Share Posted August 30, 2021 42 minutes ago, Oddfellow said: Toolstation does cheap throw-away brushes much cheaper than this. If you're just using them for resin, these are perfect. Not so goon on gel as they tend to shed a bit, but if you condition them before use, they are better. https://www.toolstation.com/paintbrush-set/p48839 These have gone up my 50% in the last 14 months. They used to be £0.99p Ah, thanks for that. I just went to Toolstation to get my polyurethane glue, then to Lidl! Next time... Quote Link to comment Share on other sites More sharing options...
TheQ Posted September 2, 2021 Share Posted September 2, 2021 Yep the thinners / brush cleaner used to clean brushes is more expensive than a cheap brush. I buy brushes in Bulk for fibreglass work and where paint work does not need to be of the highest quality (down in the bilge etc) and was getting them at 20 to 30p from Amazon, I see they are now just over 40p EA for 24 2 inch brushes.. 1 Quote Link to comment Share on other sites More sharing options...
DaveRolaves Posted September 2, 2021 Share Posted September 2, 2021 Good brushes from East Coast fibreglass, use them for painting as well as laminating, plastic handles. Twelve two inch brushes for £11 plus VAT and carriage. Also available in other sizes Quote Link to comment Share on other sites More sharing options...
