Norfolkandgood Posted September 26, 2021 Share Posted September 26, 2021 I'm looking to spend most of my time on a Seamaster 30, cruising the broads, fairly soon. Just wondering, is this a forum where I can find good advice for kitting out with new white goods and electrical equipment, and some ideas for remodelling the inside, if I go ahead with it (maybe move galley to where the forward V berth is..maybe)? All the best Adrian Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted September 26, 2021 Share Posted September 26, 2021 19 minutes ago, Norfolkandgood said: I'm looking to spend most of my time on a Seamaster 30, cruising the broads, fairly soon. Just wondering, is this a forum where I can find good advice for kitting out with new white goods and electrical equipment, and some ideas for remodelling the inside, if I go ahead with it (maybe move galley to where the forward V berth is..maybe)? All the best Adrian A friend of mine has completely remodelled his centre cockpit seamaster moving the door to the forward cabin to the side to make a large wet room in front of the helm and a large double up front. The rear cabin has a “u” shaped saloon with the galley to stb. 1 Quote Link to comment Share on other sites More sharing options...
annv Posted September 26, 2021 Share Posted September 26, 2021 Hi Adrian Shouldn't be a problem provide you dont remove any fixed interior bulkheads that are part of the build integrity. suggest you spray foam the interior and lower hull and clean then egg shell emulsion the bilges before you rebuild John 1 Quote Link to comment Share on other sites More sharing options...
Norfolkandgood Posted September 26, 2021 Author Share Posted September 26, 2021 That sounds interesting too. Not what I had in mind, but as a novice, I've an open mind. I don't suppose you could get some photos from your pal, so I could take a look, could you? It's a bit cheeky to ask, but could be a big help. Especially as I was thinking of changing the shower area too. It's way too small as it is. Quote Link to comment Share on other sites More sharing options...
Norfolkandgood Posted September 26, 2021 Author Share Posted September 26, 2021 2 minutes ago, annv said: Hi Adrian Shouldn't be a problem provide you dont remove any fixed interior bulkheads that are part of the build integrity. John Cheers John. That's what I was thinking. Otherwise I'd leave well alone. I'm happy to sacrifice 2 berths from 6, as it's only me and the dog 😁 All the best and thanks for taking the time. Quote Link to comment Share on other sites More sharing options...
