BrundallNavy Posted November 24, 2021 Share Posted November 24, 2021 On Nipper we had a Tecma electric toilet with a single button to flush which worked fine. On Papaver we have a Dometic master flush electric toilet which has a two button three position control panel which requires you to push the buttons in various orders to flush. What is the best electric toilet for a boat ideally with a single button control the Jabsco looks good but not having any dealings with these I would like peoples experience before deciding whether to change ours or not. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted November 24, 2021 Share Posted November 24, 2021 You are welcome onboard 'B.A' to check ours out, I think it is a vetus unit single push button, simplest of installation 12v dc macerating type. They ain't cheap though Griff 1 Quote Link to comment Share on other sites More sharing options...
annv Posted November 24, 2021 Share Posted November 24, 2021 Hi If you discharge overboard it dosn't matter BUT if you have a holding tank a small flush for a wee and a larger flush for a poo will fill your tank up slower than if you use just one flush which will be for the larger amount to clean/clear the bowl, or a hand pump flush where you just pump the amount to clear the bowl. John Quote Link to comment Share on other sites More sharing options...
PaulN Posted November 24, 2021 Share Posted November 24, 2021 Ours is a Techma single button and it works fine, I have the control set to minimum water so that when its finished there is only just enough water to cover the outlet, this minimises what goes into the holding tank. However it does need a bigger flush for for a more 'substantial' visit, but my shower hose reaches the toilet, to add a bit more water before use, which does the trick. There is normally just the two of us onboard and we tend to pump out our 80 gallon tank about once every 2 weeks Quote Link to comment Share on other sites More sharing options...
