Changing Oil Engine & Gearbox Plus Belt
Hi Andrew the engine oil is changed each year(subject to hours run) its normal for gear boxes to be changed less frequent ie hours used (see manufactures recommendation, but oil level again each year,  the drive belt for over head camshaft like wise has a hours/miles/max time for changes ,usely several years if you mean alternator/dynamo belt no time/hours run just check for cracks and general condition also adjustment. john
