Cheesey69 Posted May 26 Share Posted May 26 You win the internet for that work! 4 1 Quote Link to comment Share on other sites More sharing options...
Karizma Posted May 26 Share Posted May 26 21 minutes ago, Cheesey69 said: You win the internet for that work! It certainly passed the time on whilst travelling through the 'boring bit' of the Bure. Quote Link to comment Share on other sites More sharing options...
Paladin Posted May 26 Share Posted May 26 1 hour ago, Karizma said: When we were at the Spring Meet some of us got talking about the Bure Hump and I said that on the way 'up north' i started monitoring the depth under the boat once we'd got past Great Yarmouth Yacht Station, as I didn't really know where the 'Bure Hump' was, so was surprised that at one point the depth got to 1.8 feet but I couldn't really remember where I was on the river , so promised to try and remember doing something similar on the way back ........ well here are the results - I found 3 'low' areas - so which one is the 'Bure Hump'? A very interesting piece of research. Thank you. To put it into context, from your post, these are the 'depth under hull' measurements. What has to be added to give an indication of overall depth? 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 26 Share Posted May 26 have you passed this document to BRAG, as I am sure they would be interested Quote Link to comment Share on other sites More sharing options...
Karizma Posted May 26 Share Posted May 26 1 hour ago, Paladin said: A very interesting piece of research. Thank you. To put it into context, from your post, these are the 'depth under hull' measurements. What has to be added to give an indication of overall depth? I'm not sure tbh, as I've never calibrated it, but I do know it's pretty accurate in showing the depth under the keel from visual checks travelling in shallow water. But if nothing else, the results are all relative to each other if not entirely accurate / scientific, and will only cost 2 litres of diesel if anybody wants me to do another one 1 Quote Link to comment Share on other sites More sharing options...
Karizma Posted May 26 Share Posted May 26 35 minutes ago, grendel said: have you passed this document to BRAG, as I am sure they would be interested yes, posted earlier. thanks 2 Quote Link to comment Share on other sites More sharing options...
Cheesey69 Posted May 28 Share Posted May 28 Just to add, hit something mid channel around start of marker posts. Sounded like going over gravel. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 28 Share Posted May 28 it is my belief that we should report incidents such as this to the broads authority, the more evidence of groundings / touching bottom, we provide them, the less they can argue that the channel is clear and to depth. especially mid channel. 1 Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted May 28 Share Posted May 28 50 minutes ago, grendel said: it is my belief that we should report incidents such as this to the broads authority, the more evidence of groundings / touching bottom, we provide them, the less they can argue that the channel is clear and to depth. especially mid channel. That may carry some weight for those properties and land that flood upstream too alerting other interested parties. This will add to pressure on flood alleviation all round Kindest Regards Marge and Parge 1 Quote Link to comment Share on other sites More sharing options...
Karizma Posted May 28 Share Posted May 28 5 hours ago, Cheesey69 said: Just to add, hit something mid channel around start of marker posts. Sounded like going over gravel. @Cheesey69 where about do the Marker Posts start in relation to my mapping? any idea? Just interested if the same area as one of my noted low points.......... 1 Quote Link to comment Share on other sites More sharing options...
William92 Posted May 28 Share Posted May 28 1 hour ago, Karizma said: @Cheesey69 where about do the Marker Posts start in relation to my mapping? any idea? Just interested if the same area as one of my noted low points.......... I had a quick look at the BA depth charts and I'm gonna place a bet - the red box I've drawn here corresponds with your 1'9" sounding, and I think that's between the 4th and 5th marker post (when heading downstream)... 2 1 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted May 29 Share Posted May 29 There used to be a cattle swim at Mautby. That might explain the gravel. 2 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted May 29 Share Posted May 29 I thought the bure hump was what Griff got when he saw phb gauge board. 4 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted May 29 Share Posted May 29 Correct and far too often Wroxham as it’s going the same way and Ludham too now Griff Quote Link to comment Share on other sites More sharing options...
rightsaidfred Posted May 29 Share Posted May 29 Is that anything like a camels hump. Fred Quote Link to comment Share on other sites More sharing options...
