ExSurveyor Posted August 10 Share Posted August 10 On the Sheerline I have a Jabesco manual pump loo fed with river water. I am fed up with the amount of weed in the pan. How easy is it to swap to a feed from the water tank. I know I will need a non return valve. Water supply to the basin is nearby that I can tap into. I will blank off the river supply and wire the valve closed. An I missing anything else. Thanks. Quote Link to comment Share on other sites More sharing options...
Mouldy Posted August 10 Share Posted August 10 25 minutes ago, ExSurveyor said: On the Sheerline I have a Jabesco manual pump loo fed with river water. I am fed up with the amount of weed in the pan. How easy is it to swap to a feed from the water tank. I know I will need a non return valve. Water supply to the basin is nearby that I can tap into. I will blank off the river supply and wire the valve closed. An I missing anything else. Thanks. You’ll need to do something with the seacock for the river water supply, surely. Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 10 Author Share Posted August 10 1 hour ago, Mouldy said: You’ll need to do something with the seacock for the river water supply, surely. Thinking of putting a stop end blank on the pipe and also wiring the seacock closed until the next lift out when I would get it removed and sealed up. 1 Quote Link to comment Share on other sites More sharing options...
rightsaidfred Posted August 10 Share Posted August 10 If mines anything to go by its just pumped through a skin fitting, I just don't use the pump with no problems. Fred 1 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 10 Author Share Posted August 10 4 minutes ago, rightsaidfred said: If mines anything to go by its just pumped through a skin fitting, I just don't use the pump with no problems. Fred That's plan B, the shower is next to the loo. It doesn't get much use. Quote Link to comment Share on other sites More sharing options...
floydraser Posted August 11 Share Posted August 11 18 hours ago, ExSurveyor said: On the Sheerline I have a Jabesco manual pump loo fed with river water. I am fed up with the amount of weed in the pan. You're on my old mooring so that's my weed, I left it there for you. If the toilet sucks up a Samsung A71 let me know. 5 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted August 11 Share Posted August 11 Surely the toilet is there to be weed into. 1 3 1 Quote Link to comment Share on other sites More sharing options...
floydraser Posted August 11 Share Posted August 11 5 minutes ago, Smoggy said: Surely the toilet is there to be weed into. And he has had the grandchildren there, where did he expect them to go? 1 Quote Link to comment Share on other sites More sharing options...
annv Posted August 11 Share Posted August 11 Hi Chairman You may find you will need a pressure vessel on the water feed if the pump keeps surging, the best place to fit the vessel is near the water pressure pump, it is also best practice to have a loop higher than the toilet with the non return valve at the top or downward slope to the toilet. John 1 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 12 Author Share Posted August 12 Having gone to Brian Wards for a new shower hose and head I managed to leave with an accumulator tank and fittings as well. As the loo has very little use I will replumb the water supply from the tank later. In the meantime time I have refitted the shower and will fit the accumulator vessel, this means I can do a final flush via the shower hose before leaving. All I am missing is a smallish single coil calorifier if anyone has one sitting in a shed 😁. Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted August 12 Share Posted August 12 On 11/08/2024 at 12:45, annv said: Hi Chairman You may find you will need a pressure vessel on the water feed if the pump keeps surging, the best place to fit the vessel is near the water pressure pump, it is also best practice to have a loop higher than the toilet with the non return valve at the top or downward slope to the toilet. John Sounds like the last chat I with my doctor. Kindest Regards Marge and Parge 1 Quote Link to comment Share on other sites More sharing options...
ZimbiIV Posted August 12 Share Posted August 12 When had a boat, why could I not go into Wards for 1 item only but come out with at least 2. Friendly and good service cost me a lot. Highly recommend them. paul 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 13 Share Posted August 13 I managed to go in and come out with just the one item I went for, probably because I didn't look around. 1 Quote Link to comment Share on other sites More sharing options...
