nollock Posted August 24 Share Posted August 24 Hello Just purchased a 4+2 shetland inboard diesel previous owner used it on french canals so regulator an bottle need changing any ideas what size bottle butane and make fits the storage compartment and which regulator is needed for marine safety Cheers Nollock first time owner Quote Link to comment Share on other sites More sharing options...
grendel Posted August 24 Share Posted August 24 I believe calor bottles are now available, but after the kerfuffle about them phasing out the smaller bottles a lot of people went over to flo gas. the best bet is to measure the compartment and see what size fits. (though for now the calor stockists can still get replacements for the smaller bottles after a policy reversal.) calor have the bottle dimensions on their website (except they dont show the 3.9kg bottles there) the flogas website has the dimensions for the different bottles under the specifications for each type. diferent manufacturers and bottle types will take different regulators so be sure to get the one that matches the bottle you purchase. Quote Link to comment Share on other sites More sharing options...
annv Posted August 24 Share Posted August 24 Hi Nollock If it doesn't have one a Bubble tester fitted inline will give you a easy fast check to make sure you dont have a gas leak each time you switch the bottle on. It also makes the 4 yearly Boat Safety Check a lot easier. John Quote Link to comment Share on other sites More sharing options...
nollock Posted August 24 Author Share Posted August 24 Thank you both for advice very kind 👍🏻 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 24 Share Posted August 24 Have a look at the Shetland Boats Group on FB, I found them very good for brand specific questions when I had a F4. Quote Link to comment Share on other sites More sharing options...
Deanno Posted August 24 Share Posted August 24 Hello, i have the same boat, have only seen one other inboard. The gas locker holds 2 of the calor 4.5 butane bottles, 1 to use and a spare. Would be interested to see the layout of the rear of your boat as the inboard restricts the seating on the back of mine. Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted August 24 Share Posted August 24 Be ware Flow gas are bigger. Lovely boat is a 4+2 only trailed out board version. They were made for Calor bottles. Investigate small patio or barbecue bottles. Kindest Regards Marge and Parge Quote Link to comment Share on other sites More sharing options...
nollock Posted August 24 Author Share Posted August 24 1 hour ago, ExSurveyor said: Have a look at the Shetland Boats Group on FB, I found them very good for brand specific questions when I had a F4. Cheers wii do Quote Link to comment Share on other sites More sharing options...
nollock Posted August 24 Author Share Posted August 24 21 minutes ago, Deanno said: Hello, i have the same boat, have only seen one other inboard. The gas locker holds 2 of the calor 4.5 butane bottles, 1 to use and a spare. Would be interested to see the layout of the rear of your boat as the inboard restricts the seating on the back of mine. Cheers for advice, will send pics tommora when i’m at boat, it was boarded over by former owner an two steps added, be interesting to see your photos if poss Quote Link to comment Share on other sites More sharing options...
nollock Posted August 24 Author Share Posted August 24 9 minutes ago, MargeandParge said: Be ware Flow gas are bigger. Lovely boat is a 4+2 only trailed out board version. They were made for Calor bottles. Investigate small patio or barbecue bottles. Kindest Regards Marge and Parge Appreciate the advice cheers Nollock Quote Link to comment Share on other sites More sharing options...
floydraser Posted August 24 Share Posted August 24 I second the comment about a bubble tester. Just had the safety cert renewed and the tester is always pleased to see one, it shows a regard for safety. 1 Quote Link to comment Share on other sites More sharing options...
nollock Posted August 25 Author Share Posted August 25 23 hours ago, Deanno said: Hello, i have the same boat, have only seen one other inboard. The gas locker holds 2 of the calor 4.5 butane bottles, 1 to use and a spare. Would be interested to see the layout of the rear of your boat as the inboard restricts the seating on the back of mine. Quote Link to comment Share on other sites More sharing options...
nollock Posted August 25 Author Share Posted August 25 Hope this helps gonna take out front half of boarding and one step to lower then re-vinyl an add two captain seats, as too high and awkward for throttle, as mentioned previous owner raised it all cos it was used on canal du midi france, be great good to see Your layout if poss? cheers Nollock Quote Link to comment Share on other sites More sharing options...
Deanno Posted August 26 Share Posted August 26 I am working away atm but will take some pics next week. This is all I have, if you sit at sides then your knees are up. No option to lower middle as inboard sits there. Quote Link to comment Share on other sites More sharing options...
