Aboattime Posted August 24, 2024 Posted August 24, 2024 So this week there has been trouble at both Potter and Wroxham. A boat was stuck across Potter,and one stuck under Wroxham that had to be towed out. 1 Quote
Broads01 Posted August 24, 2024 Posted August 24, 2024 Being stuck across Potter is quite common I think. The inexperienced don't realise it's not safe to turn close to the bridge. Clearer signage as per Reedham would be helpful. 1 Quote
grendel Posted August 25, 2024 Posted August 25, 2024 there is a big sign just before the pilots to turn before the sign, cant be much clearer 3 Quote
Mouldy Posted August 25, 2024 Posted August 25, 2024 11 hours ago, Aboattime said: and one stuck under Wroxham that had to be towed out. That I understand was in the control of one of the bridge pilots at the time. 2 Quote
Aboattime Posted August 25, 2024 Author Posted August 25, 2024 1 hour ago, Mouldy said: That I understand was in the control of one of the bridge pilots at the time. Oh dear so if the boat was damaged,i wonder who foots the repair bill.? 1 Quote
webntweb Posted August 25, 2024 Posted August 25, 2024 I presume the Bridge Pilots would be insured. 1 Quote
grendel Posted August 25, 2024 Posted August 25, 2024 here you go, big yellow exclamation mark on the bank with do not turn past this point- cant be much clearer 2 Quote
jeffbroadslover Posted August 25, 2024 Posted August 25, 2024 Hi Grendel, Have you not realised yet that a warning sign like that is similar to the ones you can see at the side of the road. You know the ones that a lot of people think " That does NOT apply to me because I think I know better" You might as well put up a sign saying "Please do not hit the bridge too hard" Jeff 2 3 Quote
Broads01 Posted August 25, 2024 Posted August 25, 2024 2 hours ago, jeffbroadslover said: Hi Grendel, Have you not realised yet that a warning sign like that is similar to the ones you can see at the side of the road. You know the ones that a lot of people think " That does NOT apply to me because I think I know better" You might as well put up a sign saying "Please do not hit the bridge too hard" Jeff I agree and the current sign is neither big enough nor scary enough. It should also be red and not yellow as yellow implies a warning rather than "danger do not". 1 Quote
