Posted
16 minutes ago, Hylander said:
Are you on the boat again Howard and Mrs Howard?        I know on the North Norfolk coast the tides have been very high recently.
Hi M no, sadly not afloat :default_crying1animated: but visiting some of our favourite places :default_beerchug: down your way later yesterday for a Norfolk v Suffolk CAMRA bowls match at the Caxton Club.
Posted
Pottering up the Chet this afternoon it was very high and still coming in. The nature reserve will have taken up a huge amount though
Hopefully down for 0900 in t morning at GYA
Posted
Andrew, there's a very useful low tide times calculator for the Broads on the Broads Society's website at http://www.norfolk-broads.org/tides/tide_report.asp   High tides are about six hours later. There's something called 'the rule of thirds' too, which you may like to google. This calculator also indicates Spring tides, which happen once a month. These tides have a wider range (high to low water) than Neaps which happen about two weeks later. Unless you're a great mathematician it's far easier just to look up the info you want in a tide table, of which there are many online. You may find the one I've mentioned above to be the easiest source of the relevant info for passing under bridges (and, maybe, for avoiding running aground !) Because the lunar month differs from the calendar month by having only 28 days (approximately), the date for Springs varies as the calendar months progress.
Be very careful when passing through Yarmouth however, as the tides are different in the Bure and the Yare, and the water moves very fast through the low and narrow bridges there. These tide tables will not give you enough info to pass safely from one river to the other, and if planning to do that you should google one of the websites dealing with the 'passage through Great Yarmouth' . I think I saw a post about it in this forum.
Posted
Spings happen twice a month, after (usually 1 or 2 days) full moon and after new moon.
Posted
In all fairness most tide times are gmt  actually ut as it's the proper time wherever you are.
I always check as tend to assume ut unless specified.
Aweigh app is your friend and is local time but no good for distant dates.
Posted
As  pointed out elsewhere , the rule of "thirds" does not really work on the Broadland rivers, but don't let me stop you looking it up 'cos out at sea it works pretty well!!!!
Posted
2 hours ago, Broads01 said:
Am I right in thinking Aweigh is updated regularly with revised predictions?
The Aweigh app has been out by at least an hour recently sometimes more, I seem to remember it was mentioned somewhere it is no longer updated.
Fred
Posted
The Broads Authority website has tide times (Gorleston) and the forecast tide heights, for the next month. It isn't difficult to work out when the spring tides are.
Posted
We are going to be seeing the highest tides of the year in the next few hours, so worth checking your lines.
Screenshot_20240919_183257_TidesNearMe.thumb.jpg.09f0c7681ed5830fdbce8436f421315d.jpg
  • Thanks 2
