A BRIDGE TOO SMALL
loribear
:wave hi everyone, you probably thought that it was only the broads bridges which stopped you getting through, well apparently not, :lol: here is a picture of a big boat trying to get through a small bridge & failing badly :lol: take a look at this,post-937-136713954875_thumb.png this guy got himself well & truly stuck :norty::norty::roll: lori :Stinky
They remind me of when we used to stay in the Cordon Rouge apartments on Wroxham bridge, before the days of the bridge pilots there, you could almost gaurantee that on a busy high season weekend, there would be at least one boat get stuck under the main archway :naughty:
We once watched the BA first try loading on more people to give extra balast and bring the boat to sit lower in the water, and when that failed, they sent for a big old workboat with a powerful pump onboard, which was used to fill the bilges of the stuck boat with many gallons of River water, which finally enabled the boat to be low enough to be pulled free, moored up at the De-masting moorings, and the process reversed to pump the river water out of its bilges.
The problem was solved somewhat when the pedestrian bridge was installed, and a row of dangling strips attached to act as a gauge to oncoming craft from downstream as a simple warning, if the strips touched any part of your boat, do not proceed with the bridge passage :norty:
Sadly it didnt take long for some pillocks to make a game of trying to remove these during a transit, and after a couple of seasons, they were almost non-existant again, and the Hire yards started insisting that no Hireboat was to transit the bridge without the services of the bridge Pilot. :Stinky
Julz :wave
Although a little tight the boat fits through the bridge just fine, the incident occurred because he tried in flood conditions. It was Chertsey bridge which although its not the most difficult it's certainly not the easiest to navigate in flood conditions.
Not sure where they got £500,000 from either!! The red flags mentioned are actually red boards at every lock, boat owners are strongly recommended to stop cruising until the waters subside but there is no law forcing them to stop. Hire boats can be forced to stop unless they have an experienced helm on board, I've done this several times and it makes Gt Yarmouth seem like a walk in the park!!
Looks like a Caprice too,
from my armchair :P it looks as if the tow vessels should have pulled the bows across the river and used the power from the boat under the bridge to squeeze her out.
I have moved boats on the Thames in strong stream conditions with the boards out and it can be dangerous. stupidly, when I was out we were eight 20 year olds on 3 boats going from Benson to Thames ditton telling the lock keepers we had forgotten our pilots signs :norty:
the locks were shut the day we arrived so we had to finish the trip but perhaps is was not a good idea sending us :naughty: as we all thought we were on holiday although on the final night I did consider leaving the boats as we were all a bit freaked out :o
We still talk about it over 15 years later, we call it the 'Pepsi Max adventure!'
:wave i'm amazed & shocked that he took it through when the water level was high, i'd ave thought being a private owner that he'd had more sense, surely he must ave known how high his boat was, & surely he'd ave know not to take it through the bridge, unless he was showing off, in which case, that was utter stupidity, lori :Stinky
