robtom Posted September 6, 2013 Share Posted September 6, 2013 Hi everyone We have just purchased a 1997 model of the above with a Nanni 85hp 5 cylinder engine and bow thruster. Engine hours are 858. The only significant problem found by the surveyor is a worn bearing on the prop shaft. It has osmosis but the surveyor said its not much worse than when he last surveyed it in 2006 for the previous owner. It seems fresh water boat owners are not overly troubled by it. If anyone knows of any issues or problems with this model, we would greatly appreciate it they would kindly let us know. Many thanks. Robtom Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted September 7, 2013 Share Posted September 7, 2013 Hello Robtom,Welcome to the forum from Tan & myself.Just out of interest who did your survey?I am sure someone will be along soon who knows your boat.RegardsAlan Quote Link to comment Share on other sites More sharing options...
jillR Posted September 11, 2013 Share Posted September 11, 2013 hi robtom welcome from me to jill Quote Link to comment Share on other sites More sharing options...
robtom Posted September 22, 2013 Author Share Posted September 22, 2013 Many thanks to ranworthbreeze, jill_r, and jonzo for replying to my post. I am sorry about the delay in replying but I was expecting something to flag up a contact! Anyway the surveyor was Paul Homer and the engine is indeed the 5 cylinder turbo Nanni. We are on the Thames, not the Broads, but I guess the speed limit is the same. Our biggest problem so far is the black rubber (or pvc) rubbing strake around the gunwhales and also around the stern nearer the water line. It appears to have shrunk and I need to get hold of some more of the same profile. Wilks have nothing and I can't find it anywhere on the internet. Does anyone know where I can get it, or anyone that used to work for Bounty boats who would know? Thank you in advance if you can help? Robtom Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted September 23, 2013 Share Posted September 23, 2013 Hello Robtom,I have just done a search, have a look at these links.http://www.littleportboathaven.co.uk/Fender%20Rubbers.htmhttp://www.bridgerubber.co.uk/acatalog/M02.P.V.C._Fenders___Deck_Rubbing_Strakes.htmlRegardsAlan Quote Link to comment Share on other sites More sharing options...
mbird Posted September 23, 2013 Share Posted September 23, 2013 Also worth trying Walker rubber in Norwich who make a lot of rubbing strake profiles http://www.walker-rubber.co.uk/s4/Marine.html Quote Link to comment Share on other sites More sharing options...
robtom Posted September 24, 2013 Author Share Posted September 24, 2013 Fendering Thank you all for your help. I had already tried Walker Rubber without success But LPH have something similar and I am awaiting sample. Someone at the marina suggested Trendmarine and they also have what appears to be the right profile but again I am awaiting a sample. Watch this space! Senders and gauges for the holding and water tanks.This boat has none. Has anyone had experience of fitting them? I can just get to the top of the holding tank but there isn't enough free space to drill a hole big enough for the sender. This boat has the second cabin with the 'double' berth. If I remove the panel under the mattress in the trotter box I can see the forward end of the water tank (although not reach it) and there is a small blanking plate which appears to cover a hole for a sender. Was this fitted as new? And how do I get to it? Engine There is a metal floor bearer above this, because there is not enough room for a timber bearer, but this has chafed almost through the engine inlet pipe due to its movements on its mountings. I can tape it up of course but the proper solution is to cut a notch in the metal. has anyone done this? Any help or advice gratefully received. 1 Quote Link to comment Share on other sites More sharing options...
gancanny Posted September 24, 2013 Share Posted September 24, 2013 you could try www.rubber-extrusions-seals.co.uk hope that works Quote Link to comment Share on other sites More sharing options...
robtom Posted September 24, 2013 Author Share Posted September 24, 2013 Thank you gancanny, I will give them a try. I got a sample from Trend Marine today which is very close, although not exact. Quote Link to comment Share on other sites More sharing options...
robtom Posted September 24, 2013 Author Share Posted September 24, 2013 Google can't find that company gancanny - is the address correct? Quote Link to comment Share on other sites More sharing options...
gancanny Posted September 25, 2013 Share Posted September 25, 2013 the company name appears to be GEORGE CULLEY 8, WADDINGTON FOLD ROCHDALE LANCS i just googled george culley and it came out top of the page sorry Quote Link to comment Share on other sites More sharing options...
robtom Posted September 25, 2013 Author Share Posted September 25, 2013 Thanks gancanny. I rang them but they can't help because I only need about one metre! He thinks their website has been culled by a directory as its not his. Robtom Quote Link to comment Share on other sites More sharing options...
bitingmidge Posted October 8, 2013 Share Posted October 8, 2013 Engine There is a metal floor bearer above this, because there is not enough room for a timber bearer, but this has chafed almost through the engine inlet pipe due to its movements on its mountings. I can tape it up of course but the proper solution is to cut a notch in the metal. has anyone done this? I have a similar problem, although it was the engine mount in my case so no hope of filing it down. I have wrapped the area prone to chafe in a piece of old fender held securely by a bunch of cable ties. It is a lot neater than it sounds - the fender plastic was cut to exactly the circumference of the water hose so it fits snuggly round it, and the cable ties are neatly lined up at about 35mm centres! good luck! Peter Quote Link to comment Share on other sites More sharing options...
robtom Posted October 9, 2013 Author Share Posted October 9, 2013 Thanks Peter, sounds like a good idea, I will try it. Also thanks Alan for the Littleport tip for fendering. After a lengthy wait I finally have a sample which although a smidgin too wide, is, I'm sure, as close as I'm going to get. Reagrding my question about a gauge for the water tank, i have discovered that Tektanks do a system where you can fix sender units to the outside of the tank and check the level. I haven't fitted it yet but I will report back when I do. Quote Link to comment Share on other sites More sharing options...
SPEEDTRIPLE Posted October 10, 2013 Share Posted October 10, 2013 Is the Bounty Sovreign 34 a river cruiser, or is there a coastal version, as i can`t understand why a boat designed for use on the Broads would need such a powerful turbocharged engine?. Most broads hire cruisers of that size used to be powered by the ubiquitous "Perkins 4108" or the trusty "BMC 1.5"?. I know of many Alpha 42`s that were powered by the humble BMC 1.5, and performed really well, and they only produced around 35ish hp, and even less when governed at the throttle lever. So why would the Sovereign need such an engine, especially when at "river speeds, or revs" the turbo would, as Jonzo points out, possibly suffer from clogging up?. Regards to all ...................... Neil. Quote Link to comment Share on other sites More sharing options...
Matt Posted October 11, 2013 Share Posted October 11, 2013 They are good for estuary cruising apparently.www.boatshowrooms.com/used-boats/boat-details.php?BoatID=3928177 Quote Link to comment Share on other sites More sharing options...
therealist Posted November 14, 2013 Share Posted November 14, 2013 I would rather have a bit more power than I need, I have a 37ft aquafibre with a Nanni 50hp and to be honest Id rather have the 5 cylinder engine mentioned here. Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted November 14, 2013 Share Posted November 14, 2013 is the rubber actually plastic? if so look for 63mm MDPE pipe available from capper uk or Woolsey pipe centre. needs cutting down the middle. Quote Link to comment Share on other sites More sharing options...
