Jacob Posted June 12, 2014 Share Posted June 12, 2014 Hi all, I'm a bit confused by these. I can't figure out what's positive and what's negative! Any help gratefully appreciated. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2014 Share Posted June 12, 2014 If I remember correctly, the tip is positive and the outside is negative Thinking about it, that would make a lot of sense... Agreed. Although back in the pre 60's there were some "Positive Earth" cars, I've never seen a car cigar lighter socket wired any other way than tip positive, and sleeve negative. Likewise, the overwhelming majority of small coaxial power plugs (as used on computers etc., are tip positive, sleeve negative as well. As you say, it's logical, because the positive is them more enclosed on the female sockets. Quote Link to comment Share on other sites More sharing options...
Jacob Posted June 12, 2014 Author Share Posted June 12, 2014 So this would be right? Good job I'm not an electrician! 1 Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted June 12, 2014 Share Posted June 12, 2014 So this would be right? Good job I'm not an electrician! Yes, indeed! :clap Quote Link to comment Share on other sites More sharing options...
Jacob Posted June 12, 2014 Author Share Posted June 12, 2014 Great thanks! If you hear about a burnt out boat then delete this thread! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2014 Share Posted June 12, 2014 Google images to the rescue for final confirmation https://www.google.co.uk/search?q=cigar+lighter+socket+connections&safe=off&source=lnms&tbm=isch&sa=X&ei=C9qZU5WdK6bb7Aak-oHQAw&ved=0CAcQ_AUoAg&biw=1034&bih=544#facrc=_&imgdii=_&imgrc=basedZhwlyN9jM%253A%3BBZjo7RrQDIv6LM%3Bhttp%253A%252F%252Fmarkshangout.com%252Fstorage%252Fthumbnails%252F10146638-12070109-thumbnail.jpg%253F__SQUARESPACE_CACHEVERSION%253D1304962363628%3Bhttp%253A%252F%252Fmarkshangout.com%252Fblog%252Ftag%252Fmazda%3B450%3B338 Quote Link to comment Share on other sites More sharing options...
LondonRascal Posted June 12, 2014 Share Posted June 12, 2014 The ones I got from Maplin - have a red LED in the the side but also importantly have a fuse. If this does not and your using sensitive things worth considering. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted June 12, 2014 Share Posted June 12, 2014 I agree with Robin, always use a fused cigar lighter plug. It uses a 11/4 inch fuse (32mm) and I would normally use a 5 amp fuse. Regards Alan Quote Link to comment Share on other sites More sharing options...
Jacob Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks all. Job's done all fused with no casualties. Quote Link to comment Share on other sites More sharing options...
