SteveO Posted January 9, 2009 Share Posted January 9, 2009 Does anyone know where I could get a new hinge for a folding helm seat of late 1980s vintage ? The hinge is made of aluminium in 2 sections, each of which is about 7 inches long, and allows the seat back to be folded down onto the base. One of the sections has a crack in it, where the metal is bent to fit under the seat base, which will eventually cause a break. Failing a replacement, how difficult would it be to find someone who could weld or braze the crack for me? Regards Steve Quote Link to comment Share on other sites More sharing options...
Mowjo Posted January 10, 2009 Share Posted January 10, 2009 Steve no idea about replacement hinges, but for repairs try Ken Nevard at Catfield 01692 670926 he does all that stuff and his prices and work are the best I've found so far,,,,, Regards Frank,,,, Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted January 10, 2009 Share Posted January 10, 2009 Ali welding is a bit difficult though of course possible, any chance of a photo it might help in recognition of something else to replace it. Quote Link to comment Share on other sites More sharing options...
Stranger Posted January 10, 2009 Share Posted January 10, 2009 you can buy piano hinges in about 1m lengths made out of brass from good hardware shops so you can cut it to whatever length you need should be ok for what you want http://www.cglass.co.uk/piano-hinge-pr-17203.html Quote Link to comment Share on other sites More sharing options...
jillR Posted January 10, 2009 Share Posted January 10, 2009 you can also get the piano hinges in stronger, stainless steel in alsorts of sizes. jill Quote Link to comment Share on other sites More sharing options...
Guest Posted January 10, 2009 Share Posted January 10, 2009 Have sent you a PM Steve. Quote Link to comment Share on other sites More sharing options...
SteveO Posted January 12, 2009 Author Share Posted January 12, 2009 Here are a couple of photos of the offending article. Each arm of the hinge is about 7 inches long. You can see from the second photo that I have drilled a hole at the end of the crack in an attempt to stop it from spreading further. Hope that this didn't weaken it even more! Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted January 12, 2009 Share Posted January 12, 2009 Thanks Steve, I expected they would be a bit different to piano hinges or butt hinges (hence asking for the photo's) otherwise you would just have gone out and bought some at B&Q in the first place They are simply folded from bar stock which is not a good idea with ali particularly at that bend radius as it will always fatigue crack in time. I would be tempted to get them copied by a stainless fabricator locally, I doubt the cost will be silly, drilling the hole was the correct thing to do and may well keep it OK for a while. Quote Link to comment Share on other sites More sharing options...
Guest clive_w Posted February 17, 2009 Share Posted February 17, 2009 You want a welder that does tig welding if hes any good he will sort that in 5 mins clive (Welder all my working days) Quote Link to comment Share on other sites More sharing options...
