In hull transducer base fittment
Hi looking for info on the base fitment for a in hull Airmar P79 transducer base.
Not sure if its best to epoxy fit or silicone fit to the inside of the hull.
Whatever sealant or epoxy resin I use it needs to both stick it and be waterproof as the base will contain propylene glycol to which the transducer head unit fits into.
I've been using Tec7 since it came out and can't fault it, sealed windows with it, deck fittings, underwater fittings and stuck my bilge pumps with it! sitting in oil and water and three years on I still can't move the thing,, Oh! and stuck batons on the cabin roof to fit my new ceiling up, put one in the wrong place and tried to take it down 24hrs later, gave up as it was tearing the GRP,
http://tec7.ie/product/tec7-sealant/
Frank,,,
