Timbo Posted February 20, 2016 Share Posted February 20, 2016 A week down with Royal Tudor and a bulkhead has had to be replaced. This is the bulkhead which sits side on to the cooker and the original was lined with formica...a horrible red formica. Is there any regulation within the boat safety that requires this bulkhead to be lined with anything in particular...or does it have to be lined at all? Can I use stainless or something similar? And does it have to be that horrible red, spattered with 56 years of grease, colour? Quote Link to comment Share on other sites More sharing options...
riyadhcrew Posted February 20, 2016 Share Posted February 20, 2016 The newer boats have stainless steel at the back of and to the side of the cooker, so I would presume that there is no problem with that. Best thing for ease of cleaning. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 20, 2016 Share Posted February 20, 2016 1 hour ago, Timbo said: ....... Is there any regulation within the boat safety that requires this bulkhead to be lined with anything in particular...or does it have to be lined at all? Can I use stainless or something similar?...... The BSS guidance on the subject is at 8.4.1 in the guide: "Check all appliances and all their surrounding surfaces for signs of heat damage and leaking fuel. Appliances and all their surrounding surfaces must not show signs of: scorching, blistering or discolouration; or, fuel leakage; or, smoke or soot deposits; or, heat damage or deterioration to appliance structure" from http://www.boatsafetyscheme.org/media/180428/bss%20guide%202005%20complete%20web.pdf I agree, stainless steel sheet makes a nice clean job, I always replace the cooker linings with it in all my boats. Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted February 20, 2016 Share Posted February 20, 2016 I con't recall exactly what the regulation distance is. Basically, you need flame protection within a given distance of any open gas appliance. This must be a non-combustible material - formica is combustible. However, cermaics, glass and metal are perfectly acceptable. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted February 21, 2016 Share Posted February 21, 2016 You could always nail Uncle Alberts wife to the bulkhead. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 21, 2016 Share Posted February 21, 2016 18 hours ago, FreedomBoatingHols said: I con't recall exactly what the regulation distance is. Basically, you need flame protection within a given distance of any open gas appliance. This must be a non-combustible material - formica is combustible. However, cermaics, glass and metal are perfectly acceptable. The BSS regulations for private boats are the ones I posted earlier on this thread. There is however a minimum distance in the BSS for non-private boats, but in fact they do specifically regard Formica as being acceptable as a fire retardant when fixed vertically. "It's recommended that there is a gap of at least 25mm (1ins) between an appliance and any surface which is likely to reach 50oC or above. Laminated plastic, e.g. 'Formica', can be accepted as a fire retardant when fixed in a vertical position." from http://www.boatsafetyscheme.org/boat-examination/non-private-boats/part-8-appliances,-flueing-ventilation/installation-of-cooking-appliances/ (I still prefer stainless steel or thick aluminum myself though.) Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted February 21, 2016 Share Posted February 21, 2016 Where do you get that metal sheet with the machine tooled finish? I wouldn't mind doing something like that. Quote Link to comment Share on other sites More sharing options...
FairTmiddlin Posted February 21, 2016 Share Posted February 21, 2016 The finish is not machined, but done with a hand grinder, with a backing pad and abrasive sheet. Just go across making circles = desired finish As per 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 21, 2016 Share Posted February 21, 2016 Beat me to it FairTmiddlin........ Yes, "engine turning", as it's usually referred to. https://www.google.co.uk/search?q=engine+turning&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi-weue74jLAhUH2hoKHaEHCD4Q_AUIBygB&biw=1454&bih=778&dpr=0.9#imgrc=2nhXwq_4VFV3FM%3A I use it a lot with my DIY projects when I'm using salvaged aluminum and stainless with a less than perfect surface, to save having to buff too much thickness off. Like the lifting rudder on my kayak: Quote Link to comment Share on other sites More sharing options...
Timbo Posted February 21, 2016 Author Share Posted February 21, 2016 6 hours ago, brundallNavy said: You could always nail Uncle Alberts wife to the bulkhead. Ex-wife Doug! Ex-wife! Unlike the 'short' medium on Poltergeist when I declare 'this house is clean' I make sure the shagnasties don't come swarming back! Besides which although, she has demonstrated an extremely thick skin it would be like having Lez Dawson tacked to the side of the cooker. It might put me off me dinner! Every time I put the kettle on there would be Widow Twankey gurning at me! I've sourced some aluminium and stainless steel splashbacks that I can cut to size so I will pick some up on my way down to RT on Monday. Thanks guys! Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted February 21, 2016 Share Posted February 21, 2016 You could get me to tile it for you Griff 1 Quote Link to comment Share on other sites More sharing options...
quo vadis Posted February 21, 2016 Share Posted February 21, 2016 15 minutes ago, BroadAmbition said: You could get me to tile it for you Griff Yes with polystyrene ceiling tiles Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted February 21, 2016 Share Posted February 21, 2016 Hmmm - well that'd be a first I spose (For me anyroadup) I'm currently on with tiling natural slate tiles to a clients kitchen walls - pig of a job - wish I'd never started it! Griff Quote Link to comment Share on other sites More sharing options...
BroadScot Posted February 21, 2016 Share Posted February 21, 2016 48 minutes ago, BroadAmbition said: Hmmm - well that'd be a first I spose (For me anyroadup) I'm currently on with tiling natural slate tiles to a clients kitchen walls - pig of a job - wish I'd never started it! Griff A good excuse to head to Norfolk once the job is completed Iain Quote Link to comment Share on other sites More sharing options...
Timbo Posted February 21, 2016 Author Share Posted February 21, 2016 2 hours ago, BroadAmbition said: You could get me to tile it for you Griff Ooh now that's an idea Griff! PM on the way! Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted February 22, 2016 Share Posted February 22, 2016 A good excuse to head to Norfolk once the job is completed You are not wrong and I will be this coming weekend - although not a social its a maintenance weekend Timbo - Received and replied to. I've tiled four different boats now, showers / Galleys etc Griff Quote Link to comment Share on other sites More sharing options...
Springsong Posted February 23, 2016 Share Posted February 23, 2016 Timbo Griff tiled both our head and our shower on Star Premiere and a really superb job it is too. I wish I could show you but she is all covered up at the moment. Not great photos because the space is rather confined but you can get the gist. Quote Link to comment Share on other sites More sharing options...
LondonRascal Posted February 23, 2016 Share Posted February 23, 2016 Sorry if this sounds like the 'Griff appreciation club' but he has also done a large amount of tiling for my Dad's place and the results are first class. Some examples - its still a work in progress but provides a good idea of the true quality he can achieve. Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted February 23, 2016 Share Posted February 23, 2016 On 21/02/2016 at 0:52 PM, Strowager said: Yes, "engine turning", as it's usually referred to. Another method of doing it, is to use wooden dowel rod and coat the end with valve grinding paste. It's more for doing a small piece where you need to show the finish off though. Quote Link to comment Share on other sites More sharing options...
