Brundall1037 Posted March 9, 2016 Share Posted March 9, 2016 10 minutes ago, diesel falcon said: The figure is calculated from Gorlston bar,which is a sea tide and not an inland tide, BA ,also use Gorleston bar, take 12th sat , Ba , chart says -38 org site says .42m, the minus indicates below "mean" value, so it,s only ,04 of a metre different 1.57inches (a just of wind!!) Hi, Thanks for the response but I still do not think it adds up(to me anyway). If you take Mon 14th March .org site says 0.89 and BA say 0.00. Is that not a difference of nearly 3ft? Quote Link to comment Share on other sites More sharing options...
quo vadis Posted March 9, 2016 Share Posted March 9, 2016 21 minutes ago, diesel falcon said: The figure is calculated from Gorlston bar,which is a sea tide and not an inland tide, BA ,also use Gorleston bar, take 12th sat , Ba , chart says -3.8. org site says .42m, the minus indicates below "mean" value, so it,s only ,04 of a metre different 1.57inches (a gust of wind!!) What Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted March 9, 2016 Share Posted March 9, 2016 15 minutes ago, Brundall1037 said: Hi, Thanks for the response but I still do not think it adds up(to me anyway). If you take Mon 14th March .org site says 0.89 and BA say 0.00. Is that not a difference of nearly 3ft? no that,s 0.00 which is mean 1meter at gorleston bar so it,s 1.00 -.89 =.11 =4.3 inches, it,s not an exact science only a prediction depends how many decimal points !! Quote Link to comment Share on other sites More sharing options...
Brundall1037 Posted March 9, 2016 Share Posted March 9, 2016 37 minutes ago, diesel falcon said: no that,s 0.00 which is mean 1meter at gorleston bar so it,s 1.00 -.89 =.11 =4.3 inches, it,s not an exact science only a prediction depends how many decimal points !! Ok Thanks. That makes a bit more sense but I thought they would have been both using the same data just with different reference points, obviously not as simple as that. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted March 10, 2016 Share Posted March 10, 2016 13 hours ago, Brundall1037 said: Ok Thanks. That makes a bit more sense but I thought they would have been both using the same data just with different reference points, obviously not as simple as that. Hi Jon, For our boat heights use the BA chart, it does give the low water levels and that is what we use to pass through Yarmouth. Regards Alan Quote Link to comment Share on other sites More sharing options...
Brundall1037 Posted March 10, 2016 Share Posted March 10, 2016 19 minutes ago, ranworthbreeze said: Hi Jon, For our boat heights use the BA chart, it does give the low water levels and that is what we use to pass through Yarmouth. Regards Alan Yes, that is what I use along with http://www.eastportuk.co.uk/Tidal_Chart.aspx This gives a good indication if the predictions are going to plan as well. Only any good though just before setting off Quote Link to comment Share on other sites More sharing options...
ExUserGone Posted March 14, 2016 Share Posted March 14, 2016 I've just been talking to breydon bridge about haven clearance for easter weekend, they recon 2.6m headroom at HW on a 2.4m tide with 1.7m range, so using the rule of 12th's you should get 11' under from 3 hours after HW to 3 hours before HW, ok there's 2 draining rivers so the 12th's rule doesn't fully work as it does on open water so add 1/2 hour for a bit of extra safety, tides can easily be 1/2 hour late or early with the weather and the predicted height can be screwed up by weather too so that can mess you up as well. I hope to get snowbird under an hour after HW with radar arch down with a bit of room to spare for a good play and shakedown run on the saturday of easter weekend if the weather is good, and if nothing falls do it again on the sunday. If you have easter plans don't forget bst will throw sat and sun times an hour apart. Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 14, 2016 Author Share Posted March 14, 2016 Sadly we let this boat go as talking with the seller he admitted that the next realistic time we can get the boat out the system is June.. and on a lorry it wouldn't offer a respectable safety margin as it would be about 16feet high. Plus we want a boat we can get through the french canals and if we are having problems with the broads I suspect this would rule the french canals out. The boat we brought in the end is thankfully seaward side of any bridges and everything will collapse to give only 9ft perfect. Grace hopefully I'll do "An adventures of .." Although this was still an interesting discussion and hopefully has helped others. I'm sure we will bring our new boat to the broads one day. 3 Quote Link to comment Share on other sites More sharing options...
ExUserGone Posted March 14, 2016 Share Posted March 14, 2016 Well come on then, what is it? Quote Link to comment Share on other sites More sharing options...
Gracie Posted March 14, 2016 Share Posted March 14, 2016 "Grace hopefully I'll do an 'Adventures of'"...... You most certainly better had, Jaws, you know I will nag you until you do So best get a move on, hadn't you? Grace 2 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 14, 2016 Author Share Posted March 14, 2016 7 minutes ago, LeoMagill said: Well come on then, what is it? Broom Crown 37.. (Number 3) I'll get some pictures. We haven't completed yet so don't want to count my chickens though (But it should all happen). She's being surveyed tomorrow.. Sea trial is Saturday (all being well), take her over easter weekend/weekend after depending on funds clearing. 3 minutes ago, Gracie said: "Grace hopefully I'll do an 'Adventures of'"...... You most certainly better had, Jaws, you know I will nag you until you do So best get a move on, hadn't you? Grace Certainly will lol.. 3 Quote Link to comment Share on other sites More sharing options...
