RedRover Posted November 27, 2007 Share Posted November 27, 2007 Can you help me please? How much air venting does an engine need to run efficiently? mine at the mo is around 6" x 4" is that enough? Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 28, 2007 Share Posted November 28, 2007 There is a formula Barry, if you check how many CFM of air your motor uses, Peachment should be able to tell you, I will work it out for you. David Quote Link to comment Share on other sites More sharing options...
RedRover Posted November 28, 2007 Author Share Posted November 28, 2007 Thanks david,it should'nt be a difficult job just cut another hole and screw a vent on it.as long as it is above water,don't want to be another casualty under water. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 28, 2007 Share Posted November 28, 2007 Thanks david,it should'nt be a difficult job just cut another hole and screw a vent on it.as long as it is above water,don't want to be another casualty under water. Indeed Barry, but no point in cutting a bigger hole than you need :-D Quote Link to comment Share on other sites More sharing options...
