Guest Posted January 20, 2010 Share Posted January 20, 2010 I have a spare flat screen monitor and also a spare digi box is there anyway I can link these together to make a spare tv or are they two different formats and incompatible. The monitor is lcd. Jonathan Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2010 Share Posted January 20, 2010 The digibox is very unlikely to have a VGA 15 pin output, and most flat screen monitors don't have composite are scart inputs. You need to look at the input sockets on the monitor. It'll have a 3 row 15 pin vga socket, and maybe a DVI socket. What you need is either a scart socket, or a composite phono socket for video (yellow). Really modern monitors sometimes have HDMI sockets, as do the latest HD set top boxes. The other basic question, is does the monitor have audio (speakers and amp) ? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2010 Share Posted January 20, 2010 The monitor only has vga and audio input. The digi box only has Scart and hdmi. Jonathan Quote Link to comment Share on other sites More sharing options...
Gordon Posted January 20, 2010 Share Posted January 20, 2010 It is possible to get scart to VGA cables http://www.amazon.co.uk/Hama-SCART-To-V ... B0002W69MY I could not guarantee that it would work though you would also need to get at the audio from the scart plug somehow to divert it to the af input on the monitor Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2010 Share Posted January 21, 2010 You may be ok with that. (may be...) The audio is sorted, no problem getting a scart to phonos with the audio left and right. You can even get a scart plug with the phono sockets on the back of it, so you could then just use two phono to phono leads to connect the audio. The didgibox having an hdmi does open up more possibilities. You can get an hdmi to vga lead http://cgi.ebay.co.uk/1-8m-GOLD-PLATED- ... 27aeb25082 But, when an HDMI signal is being output, it'll be expecting 1280x720 or 1920x1080 resolution on the monitor, and anything but the latest monitors might not support that. The only way to get the lower res composite, svid, or rgb video outputs from the scart is by cables with a converter in them, which Gordon mentioned. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2010 Share Posted January 21, 2010 I bought one these hoping it would do the job but no signal on monitor. Am I missing something ? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 22, 2010 Share Posted January 22, 2010 one of what ? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2010 Share Posted January 23, 2010 Sorry forgot to add http://cgi.ebay.co.uk/2M-SCART-LEAD-TO- ... 2070wt_734 Jonathan Quote Link to comment Share on other sites More sharing options...
Pete Posted January 23, 2010 Share Posted January 23, 2010 Sorry forgot to add http://cgi.ebay.co.uk/2M-SCART-LEAD-TO- ... 2070wt_734 Jonathan From that description: *Not suitable for monitors designed solely for computer use. (The screen must support a horizontal scan rate of 15.625KHz- MOST projectors, plasma and LCD panels do whereas CRT monitors dont) Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2010 Share Posted January 23, 2010 But I thought it was a flat screen... If there's no display, I wonder if the digibox is pushing out to high a resolution for the panel ? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2010 Share Posted January 23, 2010 It seems what I need is one of these and it has no audio out ,but at the price might as well buy another tv http://www.maplin.co.uk/Module.aspx?ModuleNo=37141 Thanks for the help Jonathan Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2010 Share Posted January 23, 2010 Hi Jonathon wont one of these do ?? http://shop.ebay.co.uk/i.html?LH_PrefLoc=1&_nkw=SCART%20to%20VGA&_dmpt=UK_Computing_CablesConnectors_RL&_fln=1&_trksid=p3286.c0.m283 Jonny Quote Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2010 Share Posted January 25, 2010 Tried one Jonny see earlier post. I have now bought one of these. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _582wt_950 Jonathan Quote Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2010 Share Posted January 25, 2010 Tried one Jonny see earlier post. I have now bought one of these. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _582wt_950 Jonathan Hi Jonathon those multi box things are also in that link you will have to let me know how you get on with it? Jonny Quote Link to comment Share on other sites More sharing options...
