mikeyboy1966 Posted September 6, 2023 Author Share Posted September 6, 2023 46 minutes ago, annv said: Hi Mike Just had a thought you have attached the field wire to the correct terminal ! not the rev counter terminal. Just a thought. And have you checked the output voltage at the alternator terminal. John I’ll be double checking everything at the weekend Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted September 10, 2023 Author Share Posted September 10, 2023 Well, that was a big fat FAIL. existing alternator drilled at 12mm for a 7/16 bolt, replacement drilled at 10.5 for a 10mm mounting bolt. id intended to stay over on the boat for the weekend but it was just way too hot 2 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted September 10, 2023 Author Share Posted September 10, 2023 It was also my intention to swap the brush packs as there is a small mod for the sterling power external regulator but they are slightly different. 1 Quote Link to comment Share on other sites More sharing options...
