jillR Posted April 29, 2009 Share Posted April 29, 2009 i found the macro setting last night there is a little camera shake in there on this camera i appear not to be able to use any other settings when in macro? e.g. AV for depth of field. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 29, 2009 Share Posted April 29, 2009 I suspect macro is probably a "scene" mode in which case no, it will come with preconfigured settings which you will be unable to change. I'm not really sure I see the point in the macro scene mode myself. Better to get a proper macro lens and shoot using Av mode where you can set the other settings yourself as normal. Be aware that depth of field with macro lenses is absolutely miniscule though. Canon have a cheapish 50/f2.5 macro lens, it's really not that great as macro lenses go but it's a good starting point. It'll also be better in low light than your kit lens (owing to being a faster lens) and it doubles quite nicely as a standard prime lens if you go out and do any landscape shooting. I think the shell is the best shot so far. Quote Link to comment Share on other sites More sharing options...
jillR Posted April 29, 2009 Author Share Posted April 29, 2009 thanks simon I think the shell is the best shot so far the macro shot got the cobwebs well jill Quote Link to comment Share on other sites More sharing options...
pks1702 Posted April 29, 2009 Share Posted April 29, 2009 Hi Jill, The image quality is very good in those shots, plenty of detail and sharp to boot Quote Link to comment Share on other sites More sharing options...
jillR Posted April 29, 2009 Author Share Posted April 29, 2009 hi perry thats what i was hoping still want to get closer but it will have to wait till ive sold the boat and have more dosh would love to be able to do some gnats warts jill Quote Link to comment Share on other sites More sharing options...
Guest Posted April 30, 2009 Share Posted April 30, 2009 What focal length were you using Jill? To get closer you'll need a longer focal length and, as I have discovered recently whilst looking for one, dedicated macros go up in cost very quickly as the focal length gets longer. I am very impressed with the sharpness from that kit lens. Quote Link to comment Share on other sites More sharing options...
jillR Posted April 30, 2009 Author Share Posted April 30, 2009 hi simon What focal length were you using Jill? 35mm for the 1st photo of a picture which is 11" wide x 9" high 35mm for that last shot of the water buffalo netsuke, which is about 1 1/2" high x 2 1/4" long. jill Quote Link to comment Share on other sites More sharing options...
Guest Posted May 3, 2009 Share Posted May 3, 2009 would love to be able to do some gnats warts Jill, You could always borrow this! But would need a camera adaptor to fit on the head. Maybe someone on here could help in that department? Fairly certain you'll get the Gnats warts, including all those creepy bits wriggling around inside the warts! Regards, Clive Quote Link to comment Share on other sites More sharing options...
jillR Posted May 3, 2009 Author Share Posted May 3, 2009 hi clive that would be brill nature close up looks amazing jill Quote Link to comment Share on other sites More sharing options...
