Palmtree Posted December 30, 2010 Share Posted December 30, 2010 Hi, I was up at the boatyard yesterday spraying wood preserver around the inside of the hull. In the past the boat has been painted with Bilge paint and traces of this are left. If the wood is painted I assume the wood preserver will just run off and not penetrate into the wood, or will the paint protect the wood instead. The fact bilge paint is made suggests it does have a function, so what does it do and is it a good idea to use bilge paint on a wooden hull? Ian Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 30, 2010 Share Posted December 30, 2010 I would imagine that paint serves the same purpose as wood preserver Ian, i.e. to provide a barrier against too much moisture penetrating the wood. Paint is probably more appropriate in an inboard boat where it makes the engine bilge easier to keep clean as it provides a smooth coat unlike wood preserver. From a purely logical standpoint I would have thought a product like wood preserver is more effective due to its greater penetrative quality also it often contains an ani fungal and incecticidal element. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 30, 2010 Share Posted December 30, 2010 Paint is probably more appropriate in an inboard boat where it makes the engine bilge easier to keep clean as it provides a smooth coat unlike wood preserver. That's my understanding anyway. I've used International's "Danboline" on many boats, wooden and glassfibre. It goes on to any substrate without needing a primer or undercoat, and provides a hard smooth coating which is resistant to oil and fuel. As long as you degrease carefully first, you can really tidy up a bilge or engine room very easily and quickly. I find the grey covers very well with just one coat, but the white needs several. I'm not sure how effective wood preserver would be in an enclosed space with standing water. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2010 Share Posted December 31, 2010 the main reason behind a bilge paint is to serve as a barrier to prevent oil/water/petrol etc to seep into the wood of the hull, it is also when smoothly applied on all hulls to try and prevent dirt collecting in low spots to allow for a nice clean looking bilge, as a smooth bilge is easier to clean. a wood preserver would soak into the wood to prevent rot however would provide little protection from contaminates moisture soaking in. Danboline is a good product however If I remember correctly should usually use it with International Yacht Primer on a wooden boat. HTH Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2010 Share Posted December 31, 2010 If I remember correctly should usually use it with International Yacht Primer on a wooden boat. Yes, I was wrong there Snowy. I knew it was fine on bare GRP, but was wrong with biodegradables ( ) I've found the datasheet at last: http://www.marinemegastore.com/download ... ine_GB.pdf Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2010 Share Posted December 31, 2010 always happy to help. you could possibly treat the wood with preserver and then over coat with yacht primer and danboline however I doubt anyone from international would recommend it incase the preserver and primer dont like each others company Quote Link to comment Share on other sites More sharing options...
jillR Posted December 31, 2010 Share Posted December 31, 2010 i love this gear, it does the job http://www.cuprinol.co.uk/products/5_st ... erview.jsp jill Quote Link to comment Share on other sites More sharing options...
Guest Posted January 1, 2011 Share Posted January 1, 2011 I'd used that before on my old bio degradable, seemed good stuff but have no long term experience of it, I personally like a good painted surface though. Quote Link to comment Share on other sites More sharing options...
jillR Posted January 2, 2011 Share Posted January 2, 2011 hi snowy I personally like a good painted surface though. me to if i get a chance, i will use the cuprinol before i paint bare wood. jill Quote Link to comment Share on other sites More sharing options...
Palmtree Posted January 2, 2011 Author Share Posted January 2, 2011 Hi, The Cuprinol sounds like the preservative I get from the boatyard. Every year I spray in a gallon or so when the boat has dried out on the hard standing. As I do not have an inboard engine the need for a cleanable surface is not important. What concerns me about a painted surface is if the wood moved the paint might crack and flake leaving the opportunity for water to get under the paint leading to rot (however the preservative spray would also penetrate these points as well so I suppose that is not a problem). With the new year just started it is good to think the new season is on the way Ian Quote Link to comment Share on other sites More sharing options...
