Guest Posted July 18, 2011 Share Posted July 18, 2011 I have a JGM Madeira with a rather loud BMC engine under my feet. At anything above 2500rpm it's difficult to have a conversation. I don't have any soundproofing and the vents to the engine compartment are inside the cockpit which makes it even louder. I have been looking at ASAP supplies and have seen the soundproofing sheets that are 45mm thick. They are pretty expensive and the engine bay area on the Madeira is big, the entire area under the cockpit floor which includes fuel and water tanks. Has anyone else added soundproofing to a Madeira or Elysian? What I was thinking of doing is putting a sheet under each of the two hatches that run down the centre of the cockpit directly over the engine and then boxing the sides of the engine in with more sheets. That way I could cut down on the amount it would take to cover the entire area. I'm guessing this would work ok, there is plenty of room around the engine to do this. Obviously the engine needs air, could I run a piece of hose through the soundproofing sheets to the air intake? Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted July 18, 2011 Share Posted July 18, 2011 Hi, a few years ago had the same problem with a ford 2.5 in an opened back fishing boat,cost me a fortune to line the engine bay,at the time i investigated a company who made a wraparound cover for the engine i think it was around a hundred pounds ,worth a google Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted July 18, 2011 Share Posted July 18, 2011 Found one......http://www.noisekillergb.com/product_de ... ?ItemID=91 Quote Link to comment Share on other sites More sharing options...
GrantS Posted July 18, 2011 Share Posted July 18, 2011 Hi, I had too much noise coming from the engine bay from mine, mainly due to the original engine being petrol and now it has a Turbo Diesel. I purchased Class O foam from a company that specialise in sound proofing. I explained what i wanted to use it for and they recomended this stuff. Its totally fire retardant (tried to light it with a lighter and it definately don't burn) and is also high density ( which is what you need) I'm pretty sure they supply the marine industry anyway. I purchased two large 25mm thick sheets of it and have managed to cover the removable floor areas over the engine with two layers (50mm total) and the floor areas ajacent to that and have also soundproofed the cavity above / behind the engine. I still have a fair bit left over and i have to say, it has worked wonders. The noise level has reduced significantly (and all for approx £50 which included a £10 delivery charge.) If you are interested, i will dig the receipt out and can then tell you the company name and what size sheets i went for. (although, its bought by the metre, so you choose how much) Let me know...... Quote Link to comment Share on other sites More sharing options...
Guest Posted July 19, 2011 Share Posted July 19, 2011 If you are interested, i will dig the receipt out and can then tell you the company name and what size sheets i went for. (although, its bought by the metre, so you choose how much) Let me know...... Yes please, I'd be interested to see how much the sheets are. Quote Link to comment Share on other sites More sharing options...
GrantS Posted July 19, 2011 Share Posted July 19, 2011 Hi Cattleya, CMS Acoustic Solutions (see their website) Here is what i purchased Class O Foam 2 x 1.2 Metre Sheet 25mm thickness =£20.47 I ordered 2 sheets, = £40.94 Delivery - £10 Total = 50.94 This was purchased last year, so the price will a bit higher now. Give them a ring on - 01268 568762 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 19, 2011 Share Posted July 19, 2011 Super, thank you. Quote Link to comment Share on other sites More sharing options...
ktown Posted January 3, 2012 Share Posted January 3, 2012 I know exactly how you feel Cattleya. It's like conversation is totally out of the question, ha! 200-2500 RPM is definitely the threshold of no more talking. So what techniques did you use to soundproof the engine bay? I have been researching for a while. I did some research on this a couple months ago but never went through with it. One place that I remember that has the kind of sound blankets that I think may work are at that site. Would a blanket be able to go near the engine like that? I don't really know where to start. Quote Link to comment Share on other sites More sharing options...
ktown Posted January 3, 2012 Share Posted January 3, 2012 Also, how did the foam work for you? Quote Link to comment Share on other sites More sharing options...
