Mudweight
I'm about to make a mudweight for my Norman 18.5.
Has anyone got one from a similar sized boat that could you could measure up for me to copy?
Rough tape measurements will do - bottom diameter, top diameter and height would be ideal.
Thanks in advance.
Regards.
Mark.
Hi Mark,
I would say 6 inches diameter by the same high, filled with concrete would do..
Or 8 inch base tapering to 6 inches inch top.. although I think a non taper looks better.. I'd do out of A2 or A4 though and not mild steel though.. if it goes well you should try making and selling them ;)
cheers
Hi Mark,
cheers
Thanks Alan.
I agree with what you say about Stainless but being the typical tight Yorkshireman I like cheap so it's gonna be mild with a good coat of paint.
As for selling them I suppose I could make them to order - they do seem to be difficult to get hold of.
As you suggest I think I'll try 8" tapering to 6" and 6" high. I can always add or take off material later.
Regards.
Mark.
