gancanny Posted February 22, 2008 Share Posted February 22, 2008 my boat is fitted with a 1.5 bmc engine and hydraulic drive all fitted in the stern. my problem is noise, i bought this type of setup so i would have quiet peaceful cruising but alas!!!!! the transmission gives off a high pitched whine, not noticeable on tickover but the higher the revs the louder the whine. definately not the engine, but in my amateur opinion i would say it is the hydraulic pump or drive, but definately transmission. the performance is not affected in forward or reverse it is just this awful whine any advice or ideas would be appreciated alan Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 22, 2008 Share Posted February 22, 2008 Pot winches, trawl winch pumps, bow thrusters pumps all tend to whine but when you are working it’s not so important, on a leisure boat it’s a different story. You could possibly reduce it a bit but not completely. I would suggest some really good soundproofing, it is really surprising how good it is if you get quality stuff, we have 225hp roaring away right under our feet and you can still hold a conversation at speed but just lift one of the soundproofed hatches and it’s like being at a Quo concert. Obviously it is important to ensure it’s not any bearings whining, either engine, hydraulic pump or shaft first. BTW, you are sure it's not your turbo or supercharger kicking in ?? :-D Quote Link to comment Share on other sites More sharing options...
gancanny Posted February 23, 2008 Author Share Posted February 23, 2008 thanks for the reply antares, appreciated, i agree it definately is not the turbo on my 1.5 bmc yes i have thought of sound proofing as a last resort, but first i will try peachments or brian greenwood as they are the hydraulic specialists. i may have to replace the pump or drive or whatever but we will see. thanks again for the reply alan Quote Link to comment Share on other sites More sharing options...
