Guest stopper1941 Posted August 21, 2009 Share Posted August 21, 2009 Good evening, My boat Penguin has a fridge--it can, if it worked, run by using gas,12 volt or 240 volt I don't seem to make it work on any of them Does any body know of a person who will come out to look and maybe repair it. I am based at Beccles but in a couple of weeks I plan to start a two month cruise brian Quote Link to comment Share on other sites More sharing options...
jillR Posted August 21, 2009 Share Posted August 21, 2009 hi stopper there may be some usefull tips in this thread viewtopic.php?f=68&t=6528&p=75074&hilit=fridge#p75074 or this thread viewtopic.php?f=68&t=6466&p=74239&hilit=fridge#p74239 jill Quote Link to comment Share on other sites More sharing options...
Brian Posted August 22, 2009 Share Posted August 22, 2009 Sorry but we dont touch the gas ones. You could try a large boat yard to see who they use ? ITs more than likely that any cost of repair, would be the same as a new fridge. I had a boat one in a few weeks ago, it was a 12v one with R134a refrigerant ( only about 2 years old) compressor and controller were at fault. New compressor i was quoted £275 !!! control board £110 !!! Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted August 22, 2009 Share Posted August 22, 2009 hi sounds like an old absorbtion fridge,very inificient ,if it,s had it you could use the old case,and put in a new isotherm evaprator,and a new remote comppressor in it ,this saves trying to fit a new fridge in the space left for it,be warned though there not cheap!!.They do come with gas already charged and you have a reusable plug to conect /disconect.They are very efficient though and the smallest model only uses 0.2 amps per hour when up and running.Will try to find link trev http://www.mailspeedmarine.com/refriger ... 8067.bhtml Quote Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2009 Share Posted August 23, 2009 Sounds like a caravan fridge we had which ran on 240 or gas but 12 volt just kept it topped up for the journey home. When we bought the caravan it would not work although in lit on gas and used 240v. | was advised to leave it upside down for a couple of days to clear air locks and after that it ran fine. It worked on gravity and did not have a compressor. Hope this helps. Jonathan Quote Link to comment Share on other sites More sharing options...
Poppy Posted August 24, 2009 Share Posted August 24, 2009 Jonathan beat me to it. I have seen this work on a number of occasions. It cots nothing, and is always wort a try. Edit to add - Obviously, disconnect from gas and 12 v first Quote Link to comment Share on other sites More sharing options...
jillR Posted August 24, 2009 Share Posted August 24, 2009 i remember a fridge repair man once telling me that they used to take the fridges for a bit of a run across rough ground, give it a good bouncing about and that usualy did the trick jill Quote Link to comment Share on other sites More sharing options...
Guest Posted August 24, 2009 Share Posted August 24, 2009 i remember a fridge repair man once telling me that they used to take the fridges for a bit of a run across rough ground, give it a good bouncing about and that that usualy did the trick jill Fancy a run to southwold that should shake it up in these easterly winds Jonathan Quote Link to comment Share on other sites More sharing options...
Brian Posted August 24, 2009 Share Posted August 24, 2009 Note to others, this upside down and rocking about, doesn't work with fridges with Compressors. Quote Link to comment Share on other sites More sharing options...
