quo vadis Posted February 15, 2010 Share Posted February 15, 2010 Hi dont know if anyone can help I have a Bayliner 3055 fitted with twin Cummins Mercruiser 250 hp diesels. Starboard engine now has a green indicator light flashing on the dash, although the engine starts ok it seems to be in some sort of safe mode as it will not rev under load above 1500 rpm any idears? Quote Link to comment Share on other sites More sharing options...
jimbo Posted February 15, 2010 Share Posted February 15, 2010 Firstly welcome to the forum Does the green light not have a decal or lettering to tell you what it represents? Quote Link to comment Share on other sites More sharing options...
quo vadis Posted February 15, 2010 Author Share Posted February 15, 2010 Thanks for the welcome. It is just a small green light marked engine indicator below this light is a bigger red light marked engine warning light however this is not on. Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted February 15, 2010 Share Posted February 15, 2010 hellow and welcome to the forum....scrap it! Quote Link to comment Share on other sites More sharing options...
jimbo Posted February 15, 2010 Share Posted February 15, 2010 Out of my depth with these engines really! Have you checked the obvious things like Oil and Coolant levels? Quote Link to comment Share on other sites More sharing options...
quo vadis Posted February 15, 2010 Author Share Posted February 15, 2010 Yes tried all those even changed oil and fuel filters but to no avail Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted February 15, 2010 Share Posted February 15, 2010 hi Bob ! could this be it?? http://www.ybw.com/forums/showthread.php?t=198343 Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 15, 2010 Share Posted February 15, 2010 Obviously the ECU thinks there is something wrong even if there isn't, about all you can do yourself is check that all the sensors are nicely connected, you could try the old trick of swapping components from one lump to the other starting with the ECU. Failing that it's the Cummins man with his laptop and diagnostic software I'm afraid. Quote Link to comment Share on other sites More sharing options...
quo vadis Posted February 15, 2010 Author Share Posted February 15, 2010 Does anyone know a good cummins guy on the Norfolk broads with a laptop and software Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 15, 2010 Share Posted February 15, 2010 You may want to drop a PM tomember PJCJ if he doesn't reply here, he's just had a late model CM sorted and may have a recommendation for a mechanic. Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted February 16, 2010 Share Posted February 16, 2010 hi, bob, i was enquiring about some mercruiser parts for my engines ,and your problem came up in conversation,i ,ll post the detatls here fore everyone,s info, cummins said that Prior diesels of gt yarmouth on 01493 441383 have the software for your engine,ask for gordon, or nigel haylet. trev Quote Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2010 Share Posted February 17, 2010 Gary at Brundall Marine Services, Brundall Bay, 01603 714372, has just done a complete rebuild on our D4.2L D-Tronic (required through utter lack of use by the previous owner). Phil Quote Link to comment Share on other sites More sharing options...
