smitch6 Posted March 16, 2010 Share Posted March 16, 2010 Hiya i'm after some info please at present i have a sterling pro charger the 3 output one cost a lot of money but well worth it as its brill looks after the batteries lovely and you sure do know if a joint isn't tight as it just doesn't work anyway i'm after an inverter which changes automatically ie when on shore power i will be charging the batts but running on normal 240v then when no shore power is about it will automatically switch to the inverter and run off the batts hope that makes sense it does to me anyway lol obviously i don't want to spend ridiculous money but know these aren't cheap and i will want a pure sine wave as i have tried a modified and it sent my boiler and TV haywire i will either need a 3 output or just 1 and get another charger or keep the one i have at present my layout is engine batt engine batt 2 leisure 110ah each linked but will prob get another just to bump it up a bit as most of you know i do spend 95% of my time on board so need a system that is easy and reliable to use at the minute i'm also in the process of re-wiring the mains i have tried a proper fuse board but it melted the breaker as i have too much power being used throughout the boat all the time so i swapped it for a normal household fusebox which works fine but doesn't look right so am thinking what can i do with that as the BSS states u need lights to show its running on 240v i suppose i could just use the lights on my old board and convert them anyway i'm rambling lol look forward to hearing some suggestions steve Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted March 16, 2010 Share Posted March 16, 2010 I make no comment on your general installation but if you want an auto switch that senses weather you are on shore power or inverter and automatically switches to the correct one (shorepower as default) then here’s the kiddie for you. http://www.power-store.com/view-item.asp?itemid=1359&id=223& Quote Link to comment Share on other sites More sharing options...
smitch6 Posted March 16, 2010 Author Share Posted March 16, 2010 not actually what i want but thanks anyway and i'm not sure what comment wasn't made? steve Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted March 16, 2010 Share Posted March 16, 2010 not actually what i want but thanks anyway steve "anyway i'm after an inverter which changes automatically ie when on shore power i will be charging the batts but running on normal 240v then when no shore power is about it will automatically switch to the inverter and run off the batts" Well it does exactly what you describe, well with the addition of the inverter it would anyway, are you lookingt for an inverter that has one of those actually built into it then? Quote Link to comment Share on other sites More sharing options...
smitch6 Posted March 16, 2010 Author Share Posted March 16, 2010 yes i think so Quote Link to comment Share on other sites More sharing options...
Guest Posted March 16, 2010 Share Posted March 16, 2010 Is this what you're looking for, although they don't come cheep. http://www.aquafax.co.uk/html/product_s ... p?ID=22191 Jonathan Quote Link to comment Share on other sites More sharing options...
smitch6 Posted March 16, 2010 Author Share Posted March 16, 2010 ouch Quote Link to comment Share on other sites More sharing options...
