Guest Posted October 26, 2010 Share Posted October 26, 2010 I have a Delphi pre filter fitted to my boat before the fuel lift pump. It has a metal bowl with a drain. If I open the key on the bottom to drain off any water will I have to bleed the fuel system? Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted October 26, 2010 Share Posted October 26, 2010 Probably not, it really depends on how much you have to drain. If you turn off the fuel tap whist doing it that will help, otherwise as you crack the drain fuel can run back into the tank and empty the line, then you will need to bleed. Don’t be feard if you do have to bleed though, it’s hardly a major job, yet, best if you can avoid it. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 26, 2010 Share Posted October 26, 2010 Great, thank you. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted October 26, 2010 Share Posted October 26, 2010 Probably not, it really depends on how much you have to drain. If you turn off the fuel tap whist doing it that will help, otherwise as you crack the drain fuel can run back into the tank and empty the line, then you will need to bleed. Don’t be feard if you do have to bleed though, it’s hardly a major job, yet, best if you can avoid it. I can't see why, David, as surely the weight of fuel (if your tank is nearly full) will push fuel down the line into the filter/water-separator? (just to drain a few cl's of water off) Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted October 26, 2010 Share Posted October 26, 2010 Depends if the filter is above tank level as it should be John, if so then as soon as you allow air to enter by opening the drain valve then the fuel like any fluid will find its own level by draining back as far as the level in the tank. Easier just to switch off the tap and not have the worry. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted October 27, 2010 Share Posted October 27, 2010 Of course, David. I checked ours again this morning and they are actually water traps and as such are below the tank level. They then go on to the diesel heater and the engines, all of which have their own filters. Quote Link to comment Share on other sites More sharing options...
