smitch6 Posted August 18, 2011 Share Posted August 18, 2011 Hi anyone know anywhere around yarmouth area or surrounding who makes the guard rails for boats? i can't find any that fit my boat so looks like i'm going to have to get them made up thanks steve Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted August 18, 2011 Share Posted August 18, 2011 Marine Weld at North Walsham always get good reports, the work they did for us was first class. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted August 18, 2011 Author Share Posted August 18, 2011 ok brill thanks i've just rung them and they are popping out within the next week to give a quick measure as they are working down this way were they expensive? my rails i want are 700mm high by 1.7m in length with a return of 500mm if that makes sense lol Quote Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2011 Share Posted August 18, 2011 I've used Marine Weld at North Walsham a number of times for bespoke fabrication. As Antares said, the work was first class. It's worth knowing that they are/were the OEM suppliers to Hardy Boats, also on the same industrial estate at North Walsham. They had/have a spare topsides moulding from one of the bigger Hardys in their car park, which they used to template the rails from. As regards prices though, you need to be prepared for the cost of this sort of thing from anyone ! I had an "outboard protector" bracket made to order, and it was nearly £300 , some people may think that's cheap, others may think not, but it is the going rate for made to measure "bespoke" orders.... Quote Link to comment Share on other sites More sharing options...
