OldBerkshireBoy Posted December 17, 2023 Share Posted December 17, 2023 No worries as OBO is a cousin Mine doesnt boost both types of signal and just to be clear, I didnt buy my box of tricks from that linked site only that the box of tricks and the antenna look the same but it is a minefield out there with clones and copies. On functionality etc, the cables are much longer than required so need hiding which isnt easy as the cables are thick and unwieldy and the pre fitted N type connectors are twice the size of the cable so if running them through bulkheads to the outside you will need split grommets which are not supplied. Other than that just plug in and rotate the antenna for strongest signal. 1 Quote Link to comment Share on other sites More sharing options...
