Linings On A Princess 33
oceandawn
Hi. Doe anyone have experience of replacing the side linings on a Princess 33? Can anyone be recommended? It looks as if if the windows are in two pieces and hopefully may not need to be taken out. Any thoughts will be much appreciated.
I would imagine it would be very similar build to my 30DS in which case the row of screws around the outside of the windows thread into the separate aluminium strip around the frame inside to clamp so you should be able to leave the main frames in place (but I've only had my screen out not side windows).
Wear a mask and have a good vacuum cleaner handy as the powdery mess that once disguised itself as foam backing on the vinyl will go everywhere.
