smitch6 Posted June 10, 2010 Share Posted June 10, 2010 i now have my ebby at last i spoke to the tech guy at ebeerspacher and he said i need to run a 22mm ring for my rads trouble is the pipe outlets on the unit aren't 22mm has anyone done this before if so what do i use to connect the 22mm speedfit pipe onto the unit i think they are about 19mm with a bulbous end Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 10, 2010 Share Posted June 10, 2010 You should be able to make an interface with a short length of suitable hose and a 22mm to 15mm reducer Steve. These things are primarily designed to be incorporated into a vehicle cooling system so some adaptation is always needed depending on the installation. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 10, 2010 Author Share Posted June 10, 2010 i suppose your talking about some rubber hosing like on a cars cooling system? and some jubilee clips etc you'd think that because so many of these units go into boats these days they'd have something all made for you lol looks like a trip to a car accessory shop with heater and a piece of 22mm pipe is in order then thanks Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 10, 2010 Share Posted June 10, 2010 Yes, but try to get some JCS stainless clipn instead of Jubilee if you can, JCS are made in good old Suffolk and are very high quality unlike some of the inferior Chinese made Jubilee clips. Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted June 11, 2010 Share Posted June 11, 2010 hi, what you really need is a silicone hose reducer,Straight Reducer 22mm To 16mm X 102mm Straight Reducer 22mm To 16mm X 102mm Price: £8.25 Quantity: COLOUR BLUE RED http://www.autograssparts.co.uk/index.p ... otorsport1 these are used in motorsport and won,t weep trv Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 12, 2010 Author Share Posted June 12, 2010 ok thanks i have now received all the extra fitting parts off the supplier cheap chap but slow postage (took 2 weeks to get everything here) but i'll give him his dues he did apologise and sent me a short length of exhaust and a piece of rubber hose for the water so i think thats the stuff thats usually used to i'll give it a try all i've got to do now is figure out how to fit the thing amazing all the info instructions etc none of them actually explain how to fit them lol i am still in need of a header tank unless i don't need it????? these seem to be really expensive for some reason and i presume they work like a toilet system ie with a ball float valve? otherwise how will more water get in if needed strange things these ebby's lets just hope it works well and doesn't let me down on a freezing cold night one other question pls i bought a twin calorifier also for the water i have a big ford diesel 6valve engine any ideas on how to connect it to the calorifer? as you can tell i've never done one of these before but i'll keep you informed along the way and see how we go thanks for all the help so far this place is so invaluable keep up the good work Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 13, 2010 Share Posted June 13, 2010 You do need a header tank or you can use a swirl pot, as it happens I have an all aluminium custom made one with the right entry and exit sizes that I had made for a D5W Ebo, if you don't get fixed up then it's yours for a small donation to the RNLI. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 14, 2010 Author Share Posted June 14, 2010 Thats brill ty antares not sure when your next hoping over to wrc i know you were intending on coming this past weekend if not perhaps we could arrange something but yes i'd really like it if i could many thanks steve Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 14, 2010 Share Posted June 14, 2010 I’ll get it to you somehow Steve, currently stuck in the Blackwater where we decided to go instead of North. The swirl pot is fitted just before the heater and at the highest point of the circuit. It’s quite a simple thing really, the antifreeze mixture goes in at the top and out through the bottom so any air can be removed. A radiator type cap is fitted to the top so you can top up with antifreeze mixture if you need to. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 15, 2010 Author Share Posted June 15, 2010 thats brill thanks antares i'm actually in the process of fitting it now harder than i thought lol i have the clorifier in position and water in and out and the ends ready for the ebby to connect to i also have another 2 ends ready for connection to the engine at some point, not sure how to do this either now here's the problem i am having wiring how on earth do you wire these things up lol the ebby unit has an output plug on it the control unit doesn't neither does the timer the pump has a plug and the control unit does too but they don't match i really could do with some help on the wiring end if anyone has any idea on how these things are wrired up can you gimme a shout pls and by the looks of the bracketry that came with it and the bits coming off it, it looks like it should sit in mid-air cos i can't find a flat side to it anywhere that hasn't got something coming out or going in or dangling off it lol Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 15, 2010 Author Share Posted June 15, 2010 i should add i've looked at the instructions that were posted on here but it doesn't really help me unfortunately i have a D5WZ if that makes any sense Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 21, 2010 Share Posted June 21, 2010 Back now Steve so if you PM me your address I will get it to you, there is a possibility that I will be on the broads this summer but by no means certain and in any case it would be too late for you I guess. As to the plugs not matching I can't really help without having sight though the wiring is actually (like the rest of the things) quite simple, but I will see what I can do in the way of simplifying it for you, they have various mounting brackets depending which vehicle they are mounted to and these are usually a car / van / truck makers part. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 21, 2010 Share Posted June 21, 2010 The D5WZ is normally fitted to Mercedes Sprinter vans Steve so you may well have the control system for that, do I take it that you are incorporating the heater into one of the engines cooling systems? if so you may need to fit a more complex water circuit with diverter valves operated by thermostats or you will waste a lot of heat just in the engine bay in the winter.Though these are all Webo or Ebby parts they can be difficult to source and consequentially expensive. Anyway here’s a D5WZ specific manual, it’s not the full one but does give all the wiring colours and their function so will enable you to identify them and get them hooked up even if you have to source some new plugs and sockets. Pole Volt are a good source of those things and Google will take you to their site, the other end of the current plugs may well (and I stress MAY) in fact be part of the Sprinter van’s wiring harness.d5wz.pdf Quote Link to comment Share on other sites More sharing options...
bryan123456 Posted November 24, 2010 Share Posted November 24, 2010 I don't know if this helps but there's a wiring schematic on P28. http://www.espar.com/tech_manuals/Hydro ... 3%20JE.pdf I hope you've already solved the problem - the diagram shows the cabling for socket, plug and unit - so it should be possible to work things out. There are + and - connections a + take off for the dosing pump and 3 other connectors on mine - diagnostics, alternator and switching - the latter being the one that the manufacturer wants you to only connect to their exceptionally expensive and minimalist thermostat / timer /programmer equipment. Regards, Bryan p.s. The manufacturers website also gives marine installation instructions in PDF Quote Link to comment Share on other sites More sharing options...
smitch6 Posted November 26, 2010 Author Share Posted November 26, 2010 Thanks for all the info folks sorry i haven't been on here much lately i managed to get most things wired up apart from the pump the only way i could get that to work was manually using a switch which kinda defeats the object of having a timer really if you have to flick a switch to stop it tripping itself out. anyway i have now decided to keep my combi boiler the ebby doesn't seem to do what i want it to compared with the combi boiler so i will actually have an ebby for sale and calorfier etc lol oh well more money down the drain Quote Link to comment Share on other sites More sharing options...
