rory Posted May 7, 2023 Share Posted May 7, 2023 Hi All New to this group. We are currently refurbishing a Calypso 28 and I need to connect the glow plugs to engine. The last mechanic disappeared with the old plugs and rail??! Can anyone help me with where the ends of the plug line attend to? Thanks Rory 2 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted May 8, 2023 Share Posted May 8, 2023 Hello Rory and welcome to the forum. I have a suspicion who the "last mechanic" may have been as he also disappeared halfway through a job on our boat, even leaving some of his tools on board. In which case I can recommend Daniel Austrin, who has taken over most of his business. He is very thorough and his prices are most competitive. 07781 631694. The glow plugs are negative returned through the engine block, so the positive wire goes across all of them and thus connects them in parallel. The start key is wired to the dashboard from the "battery side" terminal of the starter solenoid and the plugs are wired direct from the "heat" terminal on the key. There is a draw of about 25amps all the same, so you would be wise to install a relay somewhere near the engine, to reduce any resistance in the wiring. 2 Quote Link to comment Share on other sites More sharing options...
annv Posted May 8, 2023 Share Posted May 8, 2023 Hi Rory You dont have to have a rail/bus bar you can make your own with 50amp cable just lupe all the top terminals in a row. Plus as Vaughan said. John 2 Quote Link to comment Share on other sites More sharing options...
