Hockham Admiral Posted March 13, 2012 Share Posted March 13, 2012 With the impending hosepipe ban I am considering using a dirty water pump to supply river water (non-saline only) to my pressure washer... any comments, please? Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted March 13, 2012 Share Posted March 13, 2012 I reckon it should be fine John, provided all the big bits are filtered out. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks, David... the one I have in mind accepts debris up to 30mm. BTW, what on earth will all you Salties do? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2012 Share Posted March 13, 2012 I've had two or three pressure washers over the years, and each one was able to lift the water on it's own via the pickup hose, (as was also indicated in the instructions). Being moored in fresh water (Horning), I always use river water when power washing anyway, rather than run the meter up. I made up a special short intake hosepipe with the hozelock fitting one end, and a garden pond large pump strainer on the other.... edit - just found this in the Karcher spares section: http://www.karchercenteraquaspray.co.uk ... 40238.html Quote Link to comment Share on other sites More sharing options...
MY littleboat Posted March 13, 2012 Share Posted March 13, 2012 I thought using river water helped the green stuff grow... I may be wrong Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2012 Share Posted March 13, 2012 I thought using river water helped the green stuff grow... I may be wrong The "green stuff" grows on any surface that remains damp and is exposed to light, whether it started off as rain, river, or mains water. ( My conservatory is over half a mile away from the river, and it gets covered in it over the Winter... ) Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted March 13, 2012 Share Posted March 13, 2012 Thanks, David... the one I have in mind accepts debris up to 30mm. BTW, what on earth will all you Salties do? I shall just carry on as normal John BTW by "big" bits I mean anything you can see that isn't really soft so any decent water filter in the ine will do it, if you mean using the pressure from a water pump to supply your pressure washer as I assume you do, position the pick up a bit below any surface debis and well off the bottom and you shouldn't pick much up anyway, I have been considering fitting a proper deckwash for some time, mostly to get rid of the mud on hauling the annchor, this may be the push I need. As for your normal tank then it is potable water for hygeine and drinking, although I prefer to have bottled for that so not an issue. We always use our own hose for filling anyway as I don't trust marina ones not to have been misused so even if there are none I never have a problem, so long as there is a tap. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2012 Share Posted March 13, 2012 I have been considering fitting a proper deckwash for some time, There's a complete secondhand one on Ebay at the moment, finishing on 18th March, only £6 at the moment, though it'll probably get snipes just before the finish... http://www.ebay.co.uk/itm/Boat-Washdown ... 43ae05e956 Quote Link to comment Share on other sites More sharing options...
