Pull start problem
Hi everyone
Im sure it's a problem most people with a pull start has had before, I pull, but it doesn't engage. The odd thing however is when I take the pull start off the outboard and pull it the spikes come out like they're meant to and stay out till you let the tension off like they're meant to and when i put it all back on the engine it works like it's meant to on the first pull. But every time I go to use it again, it just doesn't engage atall until i remove the whole pull start and bolt it back on again.
I was hoping someone would have an idea as to why it does this?
P.s the whole mechanism has been sprayed with wd40 and it didn't help
Thanks in advance
BrandenJG
Until I retired, I was a mechanic for a large building company and found that
the only part to lubricate was the centre pin on which it all turned.
Anywhere else and the fingers would stick as that allowed them to collect
all sorts of crud and make them stick at the point that they should fully return.
Also check that washer.
If it still sticks, loosen the holding screws to the motor and try that. If it works
then, it must be fouling something when fully tightend.
Good luck.
