ranworthbreeze Posted May 23, 2014 Share Posted May 23, 2014 The Broads Authority is trialling a new text service to aid Broads boaters by giving the predicted time to cross Breydon Water. Please see the following link:-http://www.broads-authority.gov.uk/news-and-publications/news/new-text-service-to-help-broads-boaters Regards Alan Quote Link to comment Share on other sites More sharing options...
Happy Posted May 23, 2014 Share Posted May 23, 2014 I used this to and from the Salhouse meet. Although I had pre-checked the times using the NSBA I still thought it good piece of mind! Regards Alan Quote Link to comment Share on other sites More sharing options...
Guest Posted May 23, 2014 Share Posted May 23, 2014 That's a step in the right direction... I'd be interested to know whether the data is coming from EA via an API that no-one else is allowed access to or (having worked on a lot of public sector IT projects) whether it's just the same data that's in Broadcaster Yes, it would be really clever if it was using some real-time connection to water level height sensors to improve the accuracy of the predictions. I doubt it though. I would guess that it just uses a base level calculation for Gorleston Bar, and then applies the standard corrections for Yarmouth yacht station, and then slack water. The actual recorded height under the bridges would have been a huge step forward for users, but the link doesn't even mention tide heights, just slack times and sunrise/sunset, which are all fairly easy to get. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted May 23, 2014 Author Share Posted May 23, 2014 Hi Stowager,I am sorry to say it is the estimated level at Gorleston Bar that they text out.As you say a pity that they do not include the tide heights which is on their tide tables.Because of our air draft this is the most important part of any tide table we look at and is the main reason I personally use their tide table.RegardsAlan Quote Link to comment Share on other sites More sharing options...
CooWee Posted May 23, 2014 Share Posted May 23, 2014 "The actual recorded height under the bridges would have been a huge step forward for users, but the link doesn't even mention tide heights, just slack times and sunrise/sunset, which are all fairly easy to get." Absolutely, as it is I use the table from the NBO which works for us. Quote Link to comment Share on other sites More sharing options...
