A2 or A4 (316)?
I ordered the bolts from the manufacture of the sterndrive to bolt the transom plate onto the hull and i'm surprised to see that they have sent A2 stainless bolts.. I at least expected A4 (316) considering they will be underwater... Am I wrong and A2 is OK to use underwater?
cheers
Thanks John (sorry ;).. I found that too.. It's the salt bit of the broads which I thinks complicates things.. although I had a big long chat with the chap about the boat being in brackish water although he still sent A2 so I'm hoping he knows more.. I think I'm going to send back though and get A4.. piece of mind..
A4 is better, A2 will cause you no problems, apart from one, avoid A2 nuts as the have a habit of seizing on the threads especially nylocks, they fuse solid and even the likes of a m12 the bolt will sheer before the nut lets go!
Hi Mark
I know what you mean about stainless Nylocs. I detail structural steelwork for a living for the construction industry, and they prefer to use stainless self-locking nuts, which have a split crown rather than a nylon insert.
One question for you though, I thought I had read that A2 bolts were more prone to cavity corrosion than A4. Has that been your experience too?
A4 for me on boats, every time, especially when immersed.
I rarely use A2 even at home now, because it also has a very frequent problem with welding itself up tight due to "reaction" when first being threaded together .
Something that never happens with A4, or even mixing A4 nuts with A2 bolts or vice-versa.
