Palmtree Posted November 9, 2008 Share Posted November 9, 2008 Hi, These are the small gas cylinders with a female screw thread fitting. It looks like these are still available, but my question is can they be found in the Broads area and does anybody use them on their boat? Ian Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 9, 2008 Share Posted November 9, 2008 Hi Ian, yes they are available on the broads, Kingfisher, being a French boat was equipped with it from new and we never had any issue finding it, normally at Jeckells but it seems most places you can get it. The main difference between it and Calor is you must buy rather than rent the cylinder. Kingfisher takes the slightly smaller one and we have two to use turn about so as not to run out ever. As it happens somebody gave us an empty 907 that will not fit in the locker and you are of course welcome to it. :-D Quote Link to comment Share on other sites More sharing options...
Palmtree Posted November 9, 2008 Author Share Posted November 9, 2008 David, Thanks I will take you up on your offer To fit the cylinders do you have to rotate the cylinders of do the fittings rotate? Ian Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 9, 2008 Share Posted November 9, 2008 You have to "spin" the canister on Ian as the regulator has only a solid male thread unlike the Calor type. Quote Link to comment Share on other sites More sharing options...
senator Posted November 10, 2008 Share Posted November 10, 2008 Hi Ian, We use Camping Gaz too, Think it has something to do with availability in Europe but it is a major pain. Bottles are too small, gas is Butane only so no good under about 5 degrees and very expensive compared to Calor. We fitted Propex heating to our old Sealine on Camping gaz, heating was brilliant, far easier to install than eber's and webo's, worked perfectly but Camping Gaz prices and cappacity on board has pushed us to install a seperate diesel tank just for the heating on this boat. We have found Brooms to be consistantly lowest in price at about £15, varies a lot accross the broads have paid upto £27 at Ludham Bridge Boat yard, now we make sure there is always a spare full bottle on board. Ian Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 10, 2008 Share Posted November 10, 2008 Everything Ian (Senator) say is correct, but despite butane being supposed to be a problem below 5deg. we have never had any difficulty and have used it up to -7 once and below +5 on many occasions. Quote Link to comment Share on other sites More sharing options...
donnygeoff Posted November 10, 2008 Share Posted November 10, 2008 HI, I have 2 907 canisters that we use when camping, the regulator as Antares said just screws on, I usually take the pipe off of the rugulator and screw it on, not having to spin the canister itself. The best way to purchase them, is to buy an empty canister, I got one from ebay, about a £5, then exchanged it for a full one for about £14.00 total less than £20 for a full canister, normal cost when buying from camping shop £55 or so. If you do get one, make sure it has the carry handle that screws where the regulator goes or you could have a problem changing it for a full one. Quote Link to comment Share on other sites More sharing options...
senator Posted November 10, 2008 Share Posted November 10, 2008 As David says the +5 thing is not set in stone, we have found it works fine on the cooker and hob but the pressure drop meant that the heating didn't work on White Lady if it got below about 2 degrees, presume it is because the propex unit was more sensitive, not much comfort when it is freezing. Ian Quote Link to comment Share on other sites More sharing options...
