Where to source a piece of Meranti in Norfolk
You will probably struggle to get it "off the shelf" at that size and with a bullnose profile. You would probably need to order it (or machine down yourself).
If you are near Kent (I see you mentioned "up" to the broads). Morgans timber in Strood (Nr Rochester) (http://www.morgantimber.co.uk/) are very very good and may have off the shelf (They have a massive off cut area and you can get less than 2 meter pieces of Meranti, sapele and French oak for about a £5 a length (Longer a bit dearer). Robins in Bristol will also post to you but at a serious cost (http://www.robbins.co.uk/).  I have heard of a company similar to Morgans in Norfolk but can't remember the name..
cheers
Thanks for the ideas so far.
I should have said I am base in South Wales and swmbo will not be to happy balancing a piece of timber on her shoulder for 300 miles so the closer to Norfolk the better.
Will give Burtons a ring later.
