Alan Posted July 10, 2015 Share Posted July 10, 2015 One for those that regularly travel down from the North. Once I reach the end of the M6, I usually go A14 and then at an early opportunity go up to the A47 all the way in. Is there any great advantage going the A14 > A11 route? Quote Link to comment Share on other sites More sharing options...
Alan Posted July 10, 2015 Author Share Posted July 10, 2015 I always go A11 > A14 if travelling that way - Unless you're travelling at peak times then it's usually a good run. Because it's now dualled all the way from Norwich, it's a much better route nowadays. Saturday morning? Quote Link to comment Share on other sites More sharing options...
Mark Posted July 10, 2015 Share Posted July 10, 2015 I guess its down to how you like to travel and when, personally if I had time aplenty and did not mind the single lane and risk of congestion with caravan bulk carriers etc then the 47 is nicer... visually and calmer. I live in Felixstowe and frequently have to use the A14 all the way from the M1/M6/A14 interchange and its a slog with congestion between Huntingdon and Cambride in the busy times, but at least dualled all the way, as is the A11 virtually from leaving A14 at Newmarket to Norwich. If you can travel out of peak then try the A14/A11 and decide for yourself it will, at that time likely be faster but more boring and potentially more intense having also just done the M6 beforehand. Quote Link to comment Share on other sites More sharing options...
Alan Posted July 10, 2015 Author Share Posted July 10, 2015 I've always come the A47 way because I like the route but thought the A11 may be quicker. But then looking at the map is not nearly as good as local knowledge. We will be at the end of the M6 around 11.30. Luckily, 3 young grandchildren will be in Mum and Dad's car not mine Quote Link to comment Share on other sites More sharing options...
DaveRolaves Posted July 10, 2015 Share Posted July 10, 2015 The A14/ A11 route seems to be the better route now that the A11 has been sorted out. Quote Link to comment Share on other sites More sharing options...
Baitrunner Posted July 10, 2015 Share Posted July 10, 2015 Wow when I read that title I thought the M6 now went to Stalham I bet some of you wish it did? I'm in the blondes section with Grace now - lol. Quote Link to comment Share on other sites More sharing options...
Soundings Posted July 10, 2015 Share Posted July 10, 2015 We live in Potter and often go the other way but have found the A11/A14 the better option to/from the M6, specially so now A11 is duelled. Quote Link to comment Share on other sites More sharing options...
