Fuel Thefts Across Norfolk
Wildfuzz
We are reminding residents to be vigilant following reports of heating oil thefts from residential properties at Catfield & East Rudham within the last week.
General tips to protect your fuel include:
  • Check oil levels frequently so you are aware if anyone has tampered with your supply, and consider an electronic oil level gauge which sets off an audible alarm in your house if the oil level drops below a quarter full.
  • Fit a good quality locking device to all fuel tanks – a high quality closed shackle padlock will make access using bolt croppers very difficult.
  • Consider perimeter security for the whole tank, such as a metal cage or fencing. Even a prickly hedge may help deter thieves. Remember, however, that the oil tanker driver will need to access it.
  • Control switches should be located in a secure building and turned off when the tank is not in use.
  • If you’re installing an oil tank or considering repositioning it, they should ideally be situated within sight of nearby occupied buildings. It may not be so aesthetically desirable, but the more remote the better the opportunity to access the tank without being seen.
  • Consider appropriate lighting around the tank so you can see and anyone can be seen. Be considerate to your neighbours and don’t use high powered lights which affect their property. Lighting is not the answer to all problems and site specific advice should be taken where lighting is being considered.
If you have been a victim of oil theft, or have any information regarding heating oil thefts in general you should contact Norfolk Police on 101 or call Crimestoppers anonymously on 0800 555 111.
This can go for commercial premises, lorries and plant and boats to.
S.
