Doco Posted May 11, 2015 Share Posted May 11, 2015 Hi all just completed the roof lining in the state cabin on my Caribbean. Regards David 3 Quote Link to comment Share on other sites More sharing options...
deebee29 Posted May 11, 2015 Share Posted May 11, 2015 Hi David The roof lining looks great Quote Link to comment Share on other sites More sharing options...
Doco Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks David 1 Quote Link to comment Share on other sites More sharing options...
Doco Posted May 11, 2015 Author Share Posted May 11, 2015 The boat has a newly fitted 4000w inverter,which has allowed us to install 220v strip multi led lighting on both sides of the state room.We have dual systems 220v and 12v. Power consumption is nothing compared to the old lighting 2 Quote Link to comment Share on other sites More sharing options...
LondonRascal Posted May 11, 2015 Share Posted May 11, 2015 4000w inverter! The LED lighting though surly is low voltage DC? So you might want to bypass the ‘power brick’ knocking the 240v down to power them and run directly off the 12v supply? Be even more efficient that way. Quote Link to comment Share on other sites More sharing options...
Doco Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks Robin for sure that's right we are on the same page. We are testing at present without the brick,in our new fitted galley kitchen along the skirting board with a pr. regards David Quote Link to comment Share on other sites More sharing options...
Doco Posted May 11, 2015 Author Share Posted May 11, 2015 Galley kitchen 2 Quote Link to comment Share on other sites More sharing options...
CaptinDread Posted May 20, 2015 Share Posted May 20, 2015 how much is that tongue & groove per pack? Quote Link to comment Share on other sites More sharing options...
MBA Marine Posted May 20, 2015 Share Posted May 20, 2015 how much is that tongue & groove per pack? I used a lot on a non boat project, I dont have the invoices handy but the cheapest supplier I found locally was RS Timber next to North walsham train station. 1 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted May 21, 2015 Share Posted May 21, 2015 LEDs like a stable 12v power source which the power "brick" will provide. Running them from the 12v system on the boat will rarely give 12v but 14v or more at charge. You SHOULD use a DC to DC power converter to smooth and stabilise the supply to the LEDs if they require it. Quote Link to comment Share on other sites More sharing options...
