Ray Posted May 11, 2018 Share Posted May 11, 2018 https://www.ebay.co.uk/itm/1-5W-SOLAR-PANEL-12-VOLT-BATTERY-SAVER-TRICKLE-CHARGER-BOAT-CARAVAN-CLASSIC-CAR/332093733229?epid=13003304675&hash=item4d5254396d:g:UMcAAOxy4fVS-4hO Does anyone use this type of charger, is it effective? I can see that it will obviously have limitations but if it actually does some good it may be all I need. I guess that if it works through the 12v accessory socket (cigarette lighter thingy) then only the leisure battery will be topped up but that would be fine for me. Quote Link to comment Share on other sites More sharing options...
Daddy Mouse Posted May 11, 2018 Share Posted May 11, 2018 With an output of 1.5W it won't put a lot of juice into your batteries. On a really sunny day you might get 0.08 amps so all day to put 1 amp into you batteries cloudy days a lot less. 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted May 11, 2018 Author Share Posted May 11, 2018 Thanks, I'm an amps, volts etc dummy I'm afraid and could easily buy the wrong thing! Actually is there a basic guide that anyone can recommend, I should educate myself on this. Quote Link to comment Share on other sites More sharing options...
Daddy Mouse Posted May 11, 2018 Share Posted May 11, 2018 Have a look on 12v planet lots of simple explanations 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted May 11, 2018 Author Share Posted May 11, 2018 Just had a quick look... perfect, just what I need! Many thanks indeed! Quote Link to comment Share on other sites More sharing options...
grendel Posted May 12, 2018 Share Posted May 12, 2018 I have a small fold out solar panel that has 2 usb ports for topping up my phone while I am out and about, plus a whole raft of smaller solar powerbanks that i just leave sitting in the sun to recharge. 1 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted May 12, 2018 Share Posted May 12, 2018 Please see my post as this post reminded me I took my two off the boat when I sold. 1 Quote Link to comment Share on other sites More sharing options...
