Smoggy Posted November 21, 2019 Share Posted November 21, 2019 43 minutes ago, coolcat said: Did we wave? It was a job to tell at 24mph.... 21 knots is about what I get flat out with normal holiday loading (lots of weight), I have twin TMD41a's on shafts, I guess that means my turbos are fine. Can I ask how much it cost you or is it too painful to think about? 1 Quote Link to comment Share on other sites More sharing options...
coolcat Posted November 21, 2019 Author Share Posted November 21, 2019 12 minutes ago, Smoggy said: It was a job to tell at 24mph.... 21 knots is about what I get flat out with normal holiday loading (lots of weight), I have twin TMD41a's on shafts, I guess that means my turbos are fine. Can I ask how much it cost you or is it too painful to think about? For the fuel on the day or the turbo replacement? Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 21, 2019 Share Posted November 21, 2019 For the turbo, I know the pain of fuel all too well as I probably got through the best part of 1500+ litres last year. 1 Quote Link to comment Share on other sites More sharing options...
coolcat Posted November 21, 2019 Author Share Posted November 21, 2019 1 hour ago, Smoggy said: For the turbo, I know the pain of fuel all too well as I probably got through the best part of 1500+ litres last year. It was about £1200 fitted . Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 21, 2019 Share Posted November 21, 2019 15 minutes ago, coolcat said: It was about £1200 fitted . Ouch, but the sort of figure I imagined, I just hope mine stay good. I had a leaking oil cooler that was considered scrap by the volvo expert on the ybw forums with replacement costs at £850 (just for the cooler) so I took it off, cleaned it up at work and resoldered around the end cap of the tubestack, it still works fine and it's done two seasons since. I'll always try and fix before replacing but turbo hubs need someone that can balance them properly. 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 21, 2019 Share Posted November 21, 2019 Did they supply a full turbo or repair kit? I think the kit is a hub assembly with the turbine blades attached that you fit into your existing housings and much cheaper than a full turbo., there's not much to go wrong with the housings after all. 1 Quote Link to comment Share on other sites More sharing options...
coolcat Posted November 21, 2019 Author Share Posted November 21, 2019 6 hours ago, Smoggy said: Did they supply a full turbo or repair kit? I think the kit is a hub assembly with the turbine blades attached that you fit into your existing housings and much cheaper than a full turbo., there's not much to go wrong with the housings after all. It was a reconditioned turbo from French Marine with an exchange for the old one . Quote Link to comment Share on other sites More sharing options...
