Cheapest Lift Outs Near Brundall.
Geezercdg
When you say "look at" do you mean literally; you just want to see if it's chipped etc, or do you mean a full inspection and check the cutlass bearing?
I have an action camera with a waterproof casing which would probably go under there.
I need to measure it and work out what size has been put on. Would your camera be able to help with that? Not sure it would.
Hope you have cleaned it since last time you used it!  :default_biggrin:
