craigmc67 Posted February 2, 2022 Share Posted February 2, 2022 What’s the best way to deal with redundant skin fittings on a wood boat on the underside I have a couple and the boat is coming out in March so would be a good time to deal with them Quote Link to comment Share on other sites More sharing options...
TheQ Posted February 2, 2022 Share Posted February 2, 2022 Me I'd.. Remove old fitting, Remove paint from old plank on the inside either side of hole, Screw and epoxy a piece across the hole. Make a plug the correct size for the hole. Epoxy plug in hole, Sand, Fill , paint, as required. 5 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted February 4, 2022 Share Posted February 4, 2022 On 02/02/2022 at 13:44, craigmc67 said: What’s the best way to deal with redundant skin fittings on a wood boat on the underside Open valve and run away, you'll save a fortune... Quote Link to comment Share on other sites More sharing options...
grendel Posted February 4, 2022 Share Posted February 4, 2022 if the woods good put a bung in t ole, if its bad put a new plank in Quote Link to comment Share on other sites More sharing options...
