Victoryv Posted May 1, 2022 Share Posted May 1, 2022 Think this got lost in the outage our Perkins has developed a noise which sounds like a bearing, coming from the front of the engine, any clues? many thanks Quote Link to comment Share on other sites More sharing options...
WherryNice Posted May 2, 2022 Share Posted May 2, 2022 Do you mean a whirring type noise? I would do the old screwdriver stethescope trick to listen for where it's coming from.Engine running, get a long screwdriver, stick the handle to your ear and the tip onto the body of any spinning items(alternator/water pump etc). The same noise will be amplified into your ear if you find the culprit. Be careful of course, make sure the tip doesn't touch the spinning bits or short any electrical connections....etc Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted May 2, 2022 Share Posted May 2, 2022 22 hours ago, Victoryv said: Think this got lost in the outage our Perkins has developed a noise which sounds like a bearing, coming from the front of the engine, any clues? many thanks Are you sure Patrick is not stuck under the floorboards. Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted May 2, 2022 Share Posted May 2, 2022 Take the fan belt/s off and then run the engine briefly. If the noise has stopped you know it's a belt driven part that's failed. If the noise is still there its something more internal. If it's a belt driven part that's making the noise you'll normally be able to identify the culprit by spinning each one by hand. 3 Quote Link to comment Share on other sites More sharing options...
Victoryv Posted May 3, 2022 Author Share Posted May 3, 2022 All sorted now thank you, it was Patrick under there all along 1 Quote Link to comment Share on other sites More sharing options...
